Thread: Ok Big Issue... When i Punch
Results 1 to 8 of 8
  1. #1 Ok Big Issue... When i Punch
    Enfield, CT
    When I punch the gas pedal from a dead stop or rolling at a steady speed, the car obviously launches and the rpms go up but it hits 3500 to 3k bounces back 3500 to 3k continuously and I have no clue wth is going on. I warrantied my cat but put a ZZP cat-less DP in and tried it again. same crap. flys right up to 3500 drops to 3k real fast then 3500 then 3k. any help will be appreciated
  2. #2 Re: Ok Big Issue... When i Punch
    Traction control is kicking on. Shut it off and try it.
  3. #3 Re: Ok Big Issue... When i Punch
    Enfield, CT
    My abs wire at the bearings are fvcked. haven't had traction control for almost 7 weeks
  4. #4 Re: Ok Big Issue... When i Punch
    St. Louis
    When was the last time the fuel filter was changed? Maybe it's starving for fuel at those rpms??
  5. #5 Re: Ok Big Issue... When i Punch
    Enfield, CT
    I changed the fuel filter 8 months ago with a wix. I don't have the engine light on but I did hook up the scanner and it said P0171. I wonder if my pump is goin or something. I did put a brand new Delphi MAF in 5 weeks ago, idk if its defective
  6. #6 Re: Ok Big Issue... When i Punch
  7. #7 Re: Ok Big Issue... When i Punch
    Kansas
    I hope you are scanning the car.
  8. #8 Re: Ok Big Issue... When i Punch
    Enfield, CT
    Ik what it means and I'm gonna check for leaks around the engine bay with carb/TB spray. I also have a loss of power and of course sh!tty gas mileage. I'm getting the feeling its the new MAF or the fuel pressure regulator I bought 2 years ago. I forgot to check the pcv vavle today damnit.
  1. Loud grinding noise when I punch the gas! (2005 Grand Prix GT)
    By joshuayobal in forum General Tech Discussion
    Last Post: 01-30-2013, 02:47 PM
  2. 97 GTP issue w inside Fan/Blower issue
    By JoeRappa in forum General Tech Discussion
    Last Post: 10-03-2011, 10:16 PM
  3. punch hx2
    By isucyclones3 in forum Audio, Security & Visual Electronics
    Last Post: 07-16-2010, 10:36 AM
  4. Anyone ever wanted to punch a know it all in the face?
    By s1795so2 in forum The Rant Forum
    Last Post: 01-15-2008, 02:57 PM
