Thread: Car Jerks at WOT
Results 1 to 20 of 28
  1. #1 Car Jerks at WOT
    Mar 2012
    Altoona
    Soo, I developed a misfire a while back and I purchased new plugs & Wires . The car still jerked so I changed the coil pack .. Once I did that I guess I put 2 wires on wrong and caused the pistons to not fire in order and caused my car to feel like a diesel truck with check engine light flashing, the next day it worked fine.. Gunned it a little and no issues at all, but then my transmission went out so I had to get it rebuilt.
    Once I got the tranny rebuilt and I got my car back, I noticed jerking at WOT again so I changed the MAF sensor thinking that could be the issue, and still having the problem.. I'm not sure where to go from here..
    I seafoamed my gas, crankcase and vaccum line to see if that would fix the problem but it didnt, I got oil change .. but im still running with the same fuel filter (yes I know I need to change that) But just havn't had the time.. But I'm wondering what could be causing this..
    whenever I drive normally the car works fine but flooring it a little bit and it jerks back and forth making me unable to boost.. I'm thinking the fuel filter could be the problem or a bad pump.. not sure :// I don't want to waste money trying to figure out the problem
    Help please?
    I have a 99 GTP with 267k miles on it.
    Bottom end is rebuilt.
  2. #2 Re: Car Jerks at WOT
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    fuel pump resistor? try the bending the prong on the relay i cant post a pick but maybe some can give ya the link
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: Car Jerks at WOT
    Mar 2012
    Altoona
    Oh yeah, forgot.. I had that issue before, its already bent :P
  4. #4 Re: Car Jerks at WOT
    Sep 2012
    bridgeport,NY
    your having a fuel delivery issue how long has the pump been running on high
  5. #5 Re: Car Jerks at WOT
    Mar 2012
    Altoona
    Only about uhm.. 1000 miles,
    I heard it was fine cause newer cars run rich.. lol
  6. #6 Re: Car Jerks at WOT
    Sep 2012
    bridgeport,NY
    sounds like the pump is getting weak from the abuse
  7. #7 Re: Car Jerks at WOT
    Mar 2012
    Altoona
    Yeah probably, So do you suggest just getting a new pump? and then possibly I won't have the issue of having to pull the tab?
  8. #8 Re: Car Jerks at WOT
    Sep 2012
    bridgeport,NY
    you have a way of scanning the car while doing a run
  9. #9 Re: Car Jerks at WOT
    Mar 2012
    Altoona
    no scanners \:
  10. #10 Re: Car Jerks at WOT
    Sep 2012
    bridgeport,NY
    i would throw a pump at it and get the resistor fixed
  11. #11 Re: Car Jerks at WOT
    you still got the factory cat on the car? with those miles it could be clogged up. it will also cause the cel to flash. and make the car feel gutless.
  12. #12 Re: Car Jerks at WOT
    Mar 2012
    Altoona
    Nah, forgot to mention also..
    3" zzp catless dp. lol
  13. #13 Re: Car Jerks at WOT
    is the cel light still flashing when you get on it and it starts to jerk? and your sure the plug wires are right now?
  14. #14 Re: Car Jerks at WOT
    Mar 2012
    Altoona
    Yup, no more misfire after running obdu or w/e
    and the cel on flight once, the only code i get is the 02 sensor from the obdu or w/e
  15. #15 Re: Car Jerks at WOT
    Sep 2012
    bridgeport,NY
    can you test fuel pressure
  16. #16 Re: Car Jerks at WOT
    Mar 2012
    Altoona
    LOL dumbass me, saw vaccum leak, -.- a hose wasnt connected lol
  17. #17 Re: Car Jerks at WOT
    Mar 2012
    Altoona
    i tried gunning it, and now the car seems like it wants to turn off. my hud said check gages and once i left off the gas it was okay. so im not sure what the **** to do -.-
    as soon as i fixed the whole jerking thing, now it seems like it doesnt have power. seems like all types of little issues happening, -.-
  18. #18 Re: Car Jerks at WOT
    Sep 2012
    bridgeport,NY
    unplug the bbv soleniod
  19. #19 Re: Car Jerks at WOT
    Mar 2012
    Altoona
    and keep the hoses still connected?
  20. #20 Re: Car Jerks at WOT
    Sep 2012
    bridgeport,NY
    take off the one that goes from the solenoid to the valve
  1. Transmission jerks when car gets warm
    By Snapper in forum Introductions/Noob Questions
    Last Post: 03-15-2013, 05:18 PM
  2. trans jerks after stop
    By grey08 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-03-2012, 08:45 PM
  3. My car jerks at 4000 RPM/ Shuts off when I reverse
    By metalexa1 in forum Introductions/Noob Questions
    Last Post: 06-08-2012, 03:26 PM
  4. NEED HELP: Speedometer malfunction and car jerks
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-11-2010, 08:39 PM
  5. jerks when shifting
    By kenneth74gt in forum General Tech Discussion
    Last Post: 01-04-2009, 01:23 PM
