Thread: Replacing Gauge Cluster
Results 1 to 13 of 13
  1. #1 Replacing Gauge Cluster
    Sep 2012
    Cedar Rapids, Iowa
    My old gauge cluster got completely ****ed so I just took it out and bought a new one off eBay. As I was about to start connecting the new wires I noticed that there are two white wires, two pink wires and two green wires. All the same shade, none of them with a white or black stripe on it. How do I figure out which one goes with which?
  2. #2 Re: Replacing Gauge Cluster
    Yoga city
    you cut your old gauges out? you know theres a harness right?
  3. #3 Re: Replacing Gauge Cluster
    Sep 2012
    Cedar Rapids, Iowa
    I know there is but it was really hard to pull out so I just decided to cut the wires:\ I feel stupid about it now looking back
  4. #4 Re: Replacing Gauge Cluster
    Yoga city
    i would feel dumb to, no reason to do that. now im not sure, do you have the old cluster still?
  5. #5 Re: Replacing Gauge Cluster
    go push the tab in, and pull your plug out of your old cluster, then solder it back onto your wires, then plug it into the new cluster.
    if you tossed your old cluster, ( and the plug) you kinda crapped in your own supper.
  6. #6 Re: Replacing Gauge Cluster
    Yoga city
    thats what i was trying to figure out, if he tossed it no dice, if not though its simple.
  7. #7 Re: Replacing Gauge Cluster
    GT Level Member Shiftingshaddow's Avatar
    KC
    ouch. if you tossed them you could go to the scrap yard find a junker and pull the ends off those cables.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  8. #8 Re: Replacing Gauge Cluster
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    Why would you ever think it was going to be easier to cut the wires?
  9. #9 Re: Replacing Gauge Cluster
    St. Louis
    Let's not beat the guy up too much. Was it easier to cut the wires to remove the cluster? Yes. BUT, now it is harder to get it back in and working. Not the dumbest thing I've seen done on a car before and it can certainly be fixed w/ a little effort/input from us. We all make mistakes, just hopefully the OP will learn from this one and realize that taking shortcuts when working on a vehicle is not usually going to end well.
  10. #10 Re: Replacing Gauge Cluster
    Sep 2012
    Cedar Rapids, Iowa
    I still have the old cluster that has the plugs in it but I'm not sure how that would help me since I would still have to figure out which white/green/pink wire went with which one. If someone has a list of what each wire does I could mix and match them and plug in all the wires I know until I get it working. Thank you!
  11. #11 Re: Replacing Gauge Cluster
  12. #12 Re: Replacing Gauge Cluster
    KC
    there are multiple wires of the same color in the same plug/harness?
  13. #13 Re: Replacing Gauge Cluster
    GTX Level Member dbextreme's Avatar
    Nov 2009
    Tennessee
    What is it with Pink wires?? LOL my engine harness was FULL of them!!!!!
    1999 GPGT - L26, Ported Top Swap, XP Cam, 3.2 MPS, 42.5#, N*, LQ4, SD Headers, Double Roller, TEP Race Trans w/Stand alone Cooler, Precision Industries 3000RPM Stall, 75 Shot Nitrous Express Proton Kit w/Purge, 3" Dual Borla Pro XS, Corsa Dual 3.5 Tips, 5% Tint
    1995 Firebird Formula - Under the Knife
  1. le gauge cluster fuel gauge dnt work
    By cliffdawg in forum Visual/Body Modifications
    Last Post: 11-21-2011, 08:50 PM
  2. Swapping a 3 gauge cluster for a 6 gauge cluster
    By knoppsicle in forum General Tech Discussion
    Last Post: 10-16-2011, 09:49 PM
  3. 05 GP Gauge Cluster
    By RegorHtims in forum Audio, Security & Visual Electronics
    Last Post: 07-08-2011, 06:43 PM
  4. Gauge cluster
    By monsterjam5000 in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2010, 09:04 PM
  5. Gauge Cluster
    By lstexan in forum General Tech Discussion
    Last Post: 04-23-2010, 11:13 AM
