Thread: Service Engine Light on; But car runs fine
Results 1 to 16 of 16
  1. #1 Service Engine Light on; But car runs fine
    GT Level Member JessicaRebel's Avatar
    Jun 2011
    So.Cal: Victorville/Adelanto
    Ok so I have a 2000 Pontiac Grand Prix GT. A few months or so back, the service engine light came on while I was driving. The car didn't stutter or do anything funny, it ran perfectly fine. It did so the whole time the light was on. I had stopped driving it for a few days with not knowing and when i finally got in a drove it, less then a mile just around the street I live on it went out. It hadn't come back on, still ran fine then all of the sudden yesterday it happened again. I was driving and all of the sudden the service engine light came on yet again. Car didn't do anything funny and is still running perfectly fine.
    Any ideas as to what would cause it to do this?
    I know my AC compressor is going out but doubt it would cause it to come on.
    GPs eat sockets as Cookie Monster eats cookies.
  2. #2 Re: Service Engine Light on; But car runs fine
    Get the car scanned to see what code its throwing.
    Autozone and other parts store can scan car codes for free.
  3. #3 Re: Service Engine Light on; But car runs fine
    Jun 2011
    I must have a fail autozone near me, they say they don't do it ._. looks like its off to pepboys lol.
  4. #4 Re: Service Engine Light on; But car runs fine
    Your car is probably getting ready to explode.
  5. #5 Re: Service Engine Light on; But car runs fine
    Jun 2011
    Codes Came up
    P0128
    P0742
    P1629
    P1811
    And if my car explodes i would honestly not be shocked
  6. #6 Re: Service Engine Light on; But car runs fine
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    P0128 is a Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature) code. Probably need a new thermostat.
    P0742 is a Torque Converter Clutch Circuit Stuck On code. I can't tell you what to do for that one besides check your tranny fluid.
    P1629 is apparently a theft deterant system code? No advice for you on that one.
    P1811 is a code for the abs or wheel speed sensor I guess so you must have a bad hub or wiring or something.
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  7. #7 Re: Service Engine Light on; But car runs fine
    Jun 2011
    Thanks burgundy.
    I checked the tranny fluid and it full and looks brand new. I haven't noticed it running any cooler then normal but I may take it out to see. I don't know much about the theft fuel-enable one except to know if it could be it or not. And it doesnt shift hard, make funny noises when shifting or anything.
    I am tempted to just replace my thermostat and well if it goes off sweet if not well at least i know i have a new thermo haha.
  8. #8 Re: Service Engine Light on; But car runs fine
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    DTC P1811 Maximum Adapt and Long Shift
    The 1-2, 2-3 or 3-4 shift is longer than 0.7 seconds, twice in one trip.
    DTC P0742 Torque Converter Clutch (TCC) System - Stuck On
    The TCC release switch is closed, which indicates that the TCC is applied, 6 times for 4 seconds each during one trip.
    DTC P1629 Theft Deterrent Fuel Enable Signal Not Received
    The ECM has not received the fuel enable password from the BCM within 1 second .
    DTC P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulations Temperature
    An ECT sensor monitors the temperature of the coolant. This input is used by the control module for engine control and as an enabling criteria for some diagnostics. The air flow coming into the engine is accumulated and used to determine if the vehicle has been driven within the conditions that would allow the engine coolant to heat up normally to the thermostat regulating temperature. If the coolant temperature does not increase normally or does not reach the regulating temperature of the thermostat, the diagnostics that use ECT as enabling criteria may not run when expected. If the control module detects the calibrated amount of air flow and engine run time have been met, and the ECT has not met the minimum thermostat regulating temperature, DTC P0128 sets.
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  9. #9 Re: Service Engine Light on; But car runs fine
    Jun 2011
    Thanks Seachicken.
    I'm going to have to get it on he freeway so I can get a feel for the shifting between gears. Other then that gonna end up taking it in to get the problem more pinpointed.
    This car just has me at a loss since it is running no different then before.
  10. #10 Re: Service Engine Light on; But car runs fine
    One thing you aren't taking into account is.. which codes are old and which are current.
    When 1811 sets your transmission will slam into gear. You will definately not question if it slammed into gear, you will know. Also this code does not turn on the SES light.
    P0742 usually causes your car to stall if the TC is actually locked on.
    P1629 is going to cause the car to start and stall out. Typically working the key a couple times will fix this issue. Or replacing the ignition. I think this only sets the security light to be pissed at you once. Although since we all ignore that light... we never know it's mad until it's on solid.
    P0128, you should be able to see this on your temperature gauge. Likely it's the only current code that is causing the light to come on. Does your car take a long time to heat up, using more fuel than usual....
    If you don't have any of the above symptoms, drive the car further and have it rescanned in a few days. Whatever code you have....it'll come back.
  11. #11 Re: Service Engine Light on; But car runs fine
    Jun 2011
    Thank you so much Bill.
    Well then I know its definitley not the P1811,0742 or 1629 as the car has none of those symptoms at all. I took it out today and it didn't seem like it was warming up like it normally woul or get to the temp it normally would. As well, i do seem to use more fuel then normal. Gonna take it out for a farther drive to see and really get a good read on the temp but by what you say, I'm gonna bet its the thermostat.
  12. #12 Re: Service Engine Light on; But car runs fine
    I say skip the extra drive. Buy a thermostat and seal. Remove the two 10mm bolts while it's cold and lift the housing up. Clean your surfaces, swap the stat and put the housing back on with a light amount of RTV on it. Refill the radiator for the cup or two of coolant it lost.
    Drive and smile.
  13. #13 Re: Service Engine Light on; But car runs fine
    Jun 2011
    Gonna take your advice and just skip the drive and go ahead and replace the thermostat.
    Thanks a ton for the info bill
  14. #14 Re: Service Engine Light on; But car runs fine
    Jun 2011
    Sweet it went off!
  15. #15 Re: Service Engine Light on; But car runs fine
    Jan 2013
    Edmonton, Alberta
    if you have access to a scan tool clear the codes, some dtc's can take 100 drive cycles to clear. im not sure what a p0128 req's
  16. #16 Re: Service Engine Light on; But car runs fine
    Jun 2011
    I dont have one or know anyone with one. Im going to invest in one Though I think lol.
    I disconnected the Battery left it off a few, reconnected it and the light was off.
    Thanks all for the help!
  1. Starts, runs fine for a week, then won't start for 5 minutes, then starts and runs...
    By Summit670 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2012, 05:33 PM
  2. 04 Grand Prix engine light on but car runs fine what could this be?
    By bjornbjorn in forum General Tech Discussion
    Last Post: 12-02-2011, 12:07 AM
  3. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  4. Engine runs fine till temp starts to rise...
    By 97gpGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2010, 11:22 AM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
