Thread: issues with rear defrost and blower motor
Results 1 to 5 of 5
  1. #1 issues with rear defrost and blower motor
    GTX Level Member mofford12's Avatar
    Nov 2012
    Cincinnati
    so i pull up to the house and im sitting in the car for a sec looking at stuff and then for some strange reason something tells me to see if the rear defroster would work, and it did.. thats the first time it ever worked since i owned the car i even heard the relay click off and on.. then i decided to mess with the blower motor and of course it only works on 4 or 5.. and then out of no where i lost all power and the rear defroster wont work anymore.. so obviously a relay or wire is bad somewhere.. but where do i start?
  2. #2 Re: issues with rear defrost and blower motor
    Nov 2012
    Cincinnati
    guys come on i need to fix this lol
  3. #3 Re: issues with rear defrost and blower motor
    Jul 2012
    Homer Glen, IL
    Not sure about the rear defrost or if they are related, but the blower motor resistor could be going bad. When the resistor goes bad it can range from not working at all to full blast or nothing.
  4. #4 Re: issues with rear defrost and blower motor
    Nov 2012
    Cincinnati
    blower motor resistor has been changed.. i belive it has to do with the ignition switch
  5. #5 Re: issues with rear defrost and blower motor
    Jun 2012
    Fayetteville, GA
    Could be your ignition switch, it is a common problem. Affects blower settings 1-4 and rear defrost. Another common symptom is the key sticking in the ignition. It is caused by carbon build up on the contacts. You can either replace the switch or clean the contacts. I cleaned the contacts, and now everything works. I am a newbie for DIY projects, but I could follow the directions and get it to work. Check out this link, it is a good write up with pictures:
    ClubGP Message Forum troubleshooting
  1. POOR BLOWER MOTOR AIR FLOW (resistor and blower motor already replaced)
    By jsmit162 in forum Introductions/Noob Questions
    Last Post: 11-06-2012, 10:22 PM
  2. '05 GP base model V6, blower motor and steering issues
    By blazineagle in forum General Grand Prix Discussion
    Last Post: 07-23-2012, 07:01 PM
  3. Replies: 0
    Last Post: 02-18-2012, 01:47 PM
  4. 2004 GP blower motor / resistor / control module issues
    By revelation 6 8 in forum General Tech Discussion
    Last Post: 09-09-2011, 06:51 PM
  5. Blower motor resistor issues
    By DarkCherry in forum General Tech Discussion
    Last Post: 11-11-2010, 01:52 PM
