Re: Think it's the battery?
So I took the car to the mechanic and he was to busy to see me but hes a buddy so he scanned it and checked the readings. Apparently even the new MAF sensor isn't reading the levels for it never move so he says its prob loose wiring. He said I could check the wiring myself for any loose or damaged wires. As easy as he says?
Check the pigtail on the maf. The wires could be dry rotted there.
If they need to be replaced does anyone know where I can get a new MAF sensor connector? or how much roughly it should cost?
Search on Scottydoggs and wiring. He's written that up for many people.
autowiringsolutions_aws | eBay
for any one else looking for new pig tails, these are the guys i used off ebay. they do ls1 stuff mostly but can and will make what ever you want, and what ever color wire you want if you past stock colors.
you will need to cut the old plug off, strip the wires back till you hit clean shinny copper wire, then solder the new pig tail on.
when its header time, im checking out how much they want for a 02 extension, they have to be cheaper then zzp and the others.
Scott...would you please put that etc into an how to. Seems like a lot of people go looking for it.
