Well this car already burns enough with DoD
Sent from my DROID RAZR using Tapatalk 2
it looks like that piece is open in the middle so maybe its there just so you can see whats in the line,,,,or
I reminds me of the oil style fuel filters
like this
http://i351.photobucket.com/albums/q...x/DSC00600.jpg
or this
http://i548.photobucket.com/albums/i...f/DSC00074.jpg
(i know its nothing that those but thats what comes to mind when i see that piece
Just a guess, but maybe it's some sort of pressure tank to handle sudden pressure changes.
from your reference you're saying that people have their catch cans half full after 6 months. that sounds like a typical amount of spent oil for just about any motor ever.
can post the link your following? i seem to have seen these in the past. i think my brother was gonna put on on his truck or something.
Yea I'll post links when I go on lunch. But half a can of oil is around 300ml of oil. And other ls4 owners St its good for ls4 engine and helps slow oil consumption
And no it doesn't look anything like those pics. Look at the ones I uploaded
it is lol
http://ls1tech.com/forums/ls4-perfor...-catchcan.html
91parkave is who I talked to specifically about the catch can and I'm pretty sure he's a member here as well. He has an install thread somewhere on ls1tech for where he installed his but I can't find it on my phone right now. Its in my favorites on my computer
The scrubber is used to help catch more oil. Otherwise it will just short-circuit to the outlet. It's also beneficial to put hoses on the inlet and outlet.
Similar to what I used...just make sure they are stainless steel, because you will get a mixture of oil and water collecting in there.
Amazon.com: Stainless Steel Scrubber Pads, Set of 2 by Miles Kimball: Home Improvement
And some of the mods I did to help the catch can perform better.
Drilled the holes bigger for more flow.
http://i156.photobucket.com/albums/t...-11-54_212.jpg
Installed hoses into the catch-can on the fittings to extend them to prevent "short-circuiting"
http://i156.photobucket.com/albums/t...-46-30_219.jpg
RTV to help it seal.
http://i156.photobucket.com/albums/t...1-08-25_98.jpg
Scrubber pads
http://i156.photobucket.com/albums/t...-16-25_939.jpg
http://i156.photobucket.com/albums/t...-18-25_831.jpg
Awesome info. That hose u added...u put it on the inlet and inside the can? And u need to put rtv on a few of the seals on this one anyways cause I put low pressure air thru it and there's a couple small leaks. But the stainless steel doesn't get sucked back thru the return outlet? I appreciate all this info its expanding my knowledge on these things
Yeah, the tube goes on the inside of the can. If it's not there, the air/oil mist will mostly just go right out the outlet. With the hose, you are forcing it to travel through the entire catch-can, through all the SS mesh. That will aide greatly at keeping the oil from traveling straight through the catch-can.
The SS pad won't get sucked back through the outlet...after you push it in there, you'll see why. (It took me about a half hour to stuff one pad in there through the big drain hole in the bottom. It's never coming back out, especially through a smaller hole.)
Yea but I've noticed when I drive the 400 miles home and DoD runs it burns more. So I'm just trying to help it and slow it down some
If it was me, and you had planned on keeping the car for awhile, I would disable the DOD completly. A local ASE Master GM Tech took these of a DOD motor with about 60k on it. He said he's seen this a lot on DOD motors with 50-80K miles on them.
http://sphotos-a.xx.fbcdn.net/hphoto...40147139_n.jpg
http://sphotos-b.xx.fbcdn.net/hphoto...68542797_n.jpg
That makes since then. How hard was it to take the catch can apart? I'm gonna go pick some more rtv for sealing and then a small clear hose
Edit wow that's a lot of build up. Any other way I can help prevent that. I'm at 47500 miles now
