Thread: Hard shifting caused by fuel relay!?!?
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21 Re: Hard shifting caused by fuel relay!?!?
    Apr 2012
    Windsor
    FINALLY FIXED
    So after close to 6 months of dealing with this issue its finally gone. spending over $4000 on sensor changes and any other "guess" to what it could be, plus a full transmission rebuild...turns out the problem was the TCC sticking which was corrected by a simple PCM upgrade.
    Reference number 04-06-04-078, Anyone with similar issues just drive down to your gm dealer and get them to check for any updates for your PCM and put them in. If you go to a transmission shop like i did, you might end up paying for a rebuild you probably did not need
  2. #22 Re: Hard shifting caused by fuel relay!?!?
    PCS is typically the common issue with harsh shifting. Only symptom is code P1811 which is max adapt shift.
  1. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2012, 12:18 PM
  2. Shifting hard
    By zildjian102 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-25-2011, 08:25 PM
  3. shifting hard
    By jaredbos 1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-16-2011, 12:25 AM
  4. Maybe shifting too hard?
    By Claude in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-27-2010, 08:31 PM
  5. Hard shifting
    By Seagya in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2009, 09:50 AM
