Thread: Popping and Thumping noise.
Results 1 to 8 of 8
  1. #1 Popping and Thumping noise.
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    Recently my 02 GP GT has started making an odd popping/thumping noise from the front end. Only noticeable above about 40MPH and goes away when turning left. Is loud enough to hear inside the vehicle with the windows up and you can feel it in the steering wheel and the pedals. My initial thought was a CV axle, however I jacked the car up and there's no play in the wheel itself and the noise isn't rhythmic. Any ideas? Still looking at a CV axle most likely?
  2. #2 Re: Popping and Thumping noise.
    St. Louis
    Could be the CV. Could also be a wheel bearing. Did you check for side to side as well as up/down play on the tire?
  3. #3 Re: Popping and Thumping noise.
    Feb 2009
    Roanoke, VA
    I did check play in both directions. I just had my passenger side wheel hub replaced 3-4 months ago due to getting stuck in a mud puddle during the winter and getting mud into the wheel hub.
  4. #4 Re: Popping and Thumping noise.
    May 2012
    Cedar Rapids, Iowa
    Did you check the motor mounts?
  5. #5 Re: Popping and Thumping noise.
    Feb 2009
    Roanoke, VA
    I have not, but I didn't figure the motor mount would be making a continuous noise that's dependent upon speed and the direction of wheels at speed.... Could I be incorrect in my thinking?
  6. #6 Re: Popping and Thumping noise.
    May 2012
    Cedar Rapids, Iowa
    Sorry I totally read the op wrong. Try jacking up the car and put your hand on the spring. Rotate the tire and if and if you feel vibration, the bearing is bad. How is the tire on that side? Any abnormal wear?
  7. #7 Re: Popping and Thumping noise.
    Feb 2009
    Roanoke, VA
    No abnormal wear on the tires at all. I jacked it up and rotated both front wheels, didn't look for vibration, but listened for noise. The driver's side seemed normal, the passenger side had some noise to the rotation.
  8. #8 Re: Popping and Thumping noise.
    Feb 2009
    Roanoke, VA
    Just to tie up the thread it was a CV Axle. The last shop that worked on it never fully seated the CV axle and in turn it destroyed the axle.
  1. popping noise
    By ohagen383 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-03-2011, 08:53 AM
  2. popping noise.
    By wlmrt6 in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2010, 11:52 PM
  3. Thumping noise when braking
    By 400exHauler in forum General Tech Discussion
    Last Post: 10-11-2010, 12:46 AM
  4. Popping noise from the rear
    By tjhgtp86 in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2010, 11:29 PM
  5. thumping noise comming from front end.
    By need2know29340 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-29-2009, 11:06 PM
