Thread: HELP!!! Hit cat now ABS no longer functions
Results 1 to 6 of 6
  1. #1 HELP!!! Hit cat now ABS no longer functions
    SE Level Member ImColeTrickle's Avatar
    Apr 2011
    Athens, Alabama
    The cat cut a connection on the passenger rear of my car. It stripped the wires out of a 2-prong male connector that I'm guessing was the connection to my ABS system. I'm having a lot of trouble finding a replacement connector. Any site suggestions or part #'s will be greatly appreciated. Also on a side note since the connection was split my tuned PCM now kicks in the 110 mph limiter. is up with that?
    Crashed 1997 GP GT Mods: Ebay Intake, SSAC Headers, 2.5" ZZP Catback, Poly Uppers, Polished Aluminum DB's, ZZP 1.0 PCM, 6000k HID's
    New Car: Black 2002 GT 4dr Stock
  2. #2 Re: HELP!!! Hit cat now ABS no longer functions
    That's for your wheel speed sensor. You may have to replace the wheel bearing
    Aug 2011
    Kenosha
    If all that is damaged is the wires I would repair them. Go to your local scrap yard and cut a new connector off a Grand Prix and solder it into yours. Better than the $90 wheel bearing, unless that needs replacing anyway.
  4. #4 Re: HELP!!! Hit cat now ABS no longer functions
    Omaha, NE
    If its the male connection to the wheel hub sensor (which is the female), check rockauto. They have all sorts of Male/ Female connectors.
  5. #5 Re: HELP!!! Hit cat now ABS no longer functions
    Omaha, NE
    Here ya go.
    ACDELCO Part # PT2830
    No pic available, description reads "CONNECTOR,INLINE-TO WHL SPD SEN"
    STANDARD MOTOR PRODUCTS Part # S575
    ACDELCO Part # PT786
  6. #6 Re: HELP!!! Hit cat now ABS no longer functions
    Apr 2011
    Athens, Alabama
    Thanks alot guys
  1. glasspack longer the better?
    By bps02gtp in forum General Tech Discussion
    Last Post: 12-28-2013, 11:32 AM
  2. Which aeroforce functions does the 2000 GTP support?
    By Gasnmyveins in forum General Tech Discussion
    Last Post: 12-08-2011, 05:15 PM
  3. I'm No Longer Black...
    By JDCMoney in forum Off Topic Discussion
    Last Post: 09-04-2010, 04:11 PM
  4. no longer a 3.1
    By gtpinsc in forum Off Topic Discussion
    Last Post: 08-12-2008, 10:15 PM
