Thread: abs/traction control lights on??
Results 1 to 7 of 7
  1. #1 abs/traction control lights on??
    Jan 2013
    maple lake
    my abs and traction control light came on so i replaced my wheel bearing and the lights went off, about a week later they would come on and go off and now they are both on again, i hooked it up to a scanner and it says its my wheel speed sensor, i bought one and i heard that there are 3 of them is this correct? and how do i find out which one needs to be replaced?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    The code is usually specific to which one is bad.
    Odds are the wiring running from the wheel bearing to the ebcm is bad. Just an fyi The wires MUST be twisted. Always find the fronts going bad.. Don't recall ever doing a rear.
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: abs/traction control lights on??
    Jan 2013
    maple lake
    i cant remember what the code was i beleieve it was b00 something or close to that,
    and also i got to work today and my blower fan would not turn off had to disconnect my battery for now and ideas what that might be?
    Oct 2011
    MI
    Do you have the auto hvac setup?
  5. #5 Re: abs/traction control lights on??
    Jan 2013
    maple lake
    yes i do
    Oct 2011
    MI
    The auto hvac setup has doesn't have a resistor but instead a blower module if I remember correctly, and they are known for going bad.. Well known to continously run.
    SE Level Member Rob97gtp's Avatar
    Jul 2012
    Kansas city
    Yup the blower control module!
  1. abs and traction control lights stay on
    By John Emma in forum General Tech Discussion
    Last Post: 09-12-2012, 11:25 PM
  2. ABS and Traction Control Lights
    By MBigelow in forum General Tech Discussion
    Last Post: 07-27-2012, 07:18 PM
  3. ABS/Traction control lights
    By thirdrail37 in forum Brakes/Suspension/Chassis
    Last Post: 06-28-2011, 01:00 AM
  4. ABS & Traction Control Lights
    By 98GP*GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-08-2009, 06:40 PM
  5. '99 GT - ABS/Traction Control Lights
    By Sparg93 in forum General Tech Discussion
    Last Post: 01-15-2009, 06:21 PM
