Thread: SuperCharger problem after replacing coupling 1999 GTP
Results 1 to 4 of 4
  1. #1 SuperCharger problem after replacing coupling 1999 GTP
    Jul 2011
    MS
    Hello I have a GTP that I changed the coupling because of some play in the nose piece. Sounded like rocks rolling inside.
    Replacement went well, but as I drive it at 2500 rpm and 40mpg the boost reads 100% and engine does not seem to be pulling. at 3000 rpm the same thing!
    Help! Any Ideas?
  2. #2 Re: SuperCharger problem after replacing coupling 1999 GTP
    Take a look at the boost control soleniod by the throttle body. Did you forget to plug this in?
    When you say boost says 100%, I'm assuming you are looking at the commanded soleniod.
  3. #3 Re: SuperCharger problem after replacing coupling 1999 GTP
    Jul 2011
    MS
    Thanks, BillBoost37, I will check the hoses again. Priced a solenoid today local $50
  4. #4 Re: SuperCharger problem after replacing coupling 1999 GTP
    Please reread what I said.
    Take a look at the electrical connector. If the commanded is 100% and you are getting nothing..maybe you forgot to hook it up.
  1. replacing supercharger questions
    By Freddy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2012, 01:48 PM
  2. Supercharger coupling life?
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2011, 10:08 AM
  3. 1999 gtp 3.4 pulley supercharger problem
    By gtpzzp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2011, 02:58 PM
  4. Supercharger coupling OR Supercharger belt tensioner?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 07-23-2010, 11:56 AM
