Thread: Will a post cat O2 wire harness spliced into the upstream O2 sensor wire harness wk
Results 1 to 4 of 4
Slappyn Will a post cat O2 wire... 01-06-2013, 11:08 AM
Fivefingerdeathpunch Re: Will a post cat O2 wire... 01-06-2013, 06:16 PM
Slappyn Re: Will a post cat O2 wire... 01-06-2013, 09:49 PM
rperry435 I had to extend my wire... 01-06-2013, 10:53 PM
  1. #1 Will a post cat O2 wire harness spliced into the upstream O2 sensor wire harness wk
    Donating Users Slappyn's Avatar
    Dec 2012
    Goldsboro, NC
    I have read a lot about speed daddy headers so I picked up a pair and a new longer cabled O2 sensor (for over $50) from advanced auto since that was the best I could find locally. But yesterday I went to the junkyard and for 6 dollars I got an O2 sensor but the upstream one needed was too hard to get to so I pulled the downstream sensor and wire harness. I’m sure the wire gauge is the same so I can do a solder and heat shrink connection but I would like to do as little as possible to make it work. What does everyone think? For $6, 20 min, plus a hammer, 7/8 wrench and a knife, this seems like a good deal to me.
  2. #2 Re: Will a post cat O2 wire harness spliced into the upstream O2 sensor wire harness
    ZZP sells an o2 wire harness extension for way less than 50 bucks.
  3. #3 Re: Will a post cat O2 wire harness spliced into the upstream O2 sensor wire harness
    Dec 2012
    Goldsboro, NC
    I picked one of those up in case the junkyard setup does not work. Thanks for the help. I had read bluegtp had the info on the extender but I could not find the site.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I had to extend my wire harness for my post (non exsistant) cat on my SD Headers.
    Couldn't get my post o2 off the original downpipe. So I used an o2 from an extra rear header I had. I just cut off the plug and soldered and shrinked matching the wires. Works great.
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  1. Wire harness
    By nukkinfuttz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-05-2012, 05:44 PM
  2. abs wire harness?
    By mo1040 in forum Brakes/Suspension/Chassis
    Last Post: 03-13-2011, 01:08 PM
  3. wire harness
    By BLKGP in forum Audio, Security & Visual Electronics
    Last Post: 10-25-2009, 11:38 AM
  4. 04 GP GT Wire Harness.....
    By skubasteve! in forum Audio, Security & Visual Electronics
    Last Post: 09-25-2008, 03:41 PM
