Thread: water pump replacement
Results 1 to 15 of 15
  1. #1 water pump replacement
    May 2012
    Cedar Rapids, Iowa
    ive done a water pump on an exlporer before and i read a diy on how to do the one on the grand prix. I saw that are a couple bolts in the coolant passages. Im guessing that these get rtv right?
  2. #2 Re: water pump replacement
    its fairly easy, break the 4 bolts on the pulley loose first, then remove the belt/belts if sc.
    the take the p/s pump off, just lay it to the back. theres a hole in the pulley, at the 12 and 6 o clock position is the bolt. a 13 mm and a 3 inch extension. taking the alt off can help see a bit better working on the p/s pump.
    if your supercharged you need a t 55 to get the lower idler off. this idler and the p/s pump block bolt a bolt from coming out.
    the 4 long bolts need thread sealant on them, as they pass thought the the block to the water jacket.
    when you put it back on, the last thing you do after the belt is back on is to tighten the 4 pulley bolts.
  3. #3 Re: water pump replacement
    May 2012
    Cedar Rapids, Iowa
    sweet thanks. thread sealer=rtv right? or should i get some actual thread sealer
  4. #4 Re: water pump replacement
    plumbers thread sealant. they sell it at the parts store.
  5. #5 Re: water pump replacement
    May 2012
    Cedar Rapids, Iowa
    thanks a lot. should be tackling this tomorrow if advance auto is open.
  6. #6 Re: water pump replacement
    buy it on line, advance.com, enter the discount code at the top of their page. then pick it up, you'll save a few bucks like that.
  7. #7 Re: water pump replacement
    GTP Level Member
    Oct 2011
    Raleigh, NC
    I saw someone pull the battery also, is that really necessary ?
    1997 Red GTP 182000 miles stock
  8. #8 Re: water pump replacement
    May 2012
    Cedar Rapids, Iowa
    Yeah i did that tonight and was a little disappointed when i drove down there and they were closed. I completely spaced that it was new years eve and they might close early.
  9. #9 Re: water pump replacement
    battery can stay put, but the over flow bottle if you have one needs to go, and i moved the fuse box out of the way.
    i had a few days before i put it on, and a can of black paint, so i painted it.
  10. #10 Re: water pump replacement
    May 2012
    Cedar Rapids, Iowa
    I cant really see the battery being in the way. I saw someone pull the fuse box, which i could see helping a little, but seems like more work than necessary. it looks like a pretty easy job.
  11. #11 Re: water pump replacement
    im a rather large guy, 6'6" and wear 3 x gloves, my fore arms were getting scratched up from it, i un screwed that small nut on the top, and tied it up the fender.
    i also failed to drain any coolant Pryor to taking the pump off, i let it drain into a pan as it leaked from the water pump as the bolts came out. why dump the whole radiator???
  12. #12 Re: water pump replacement
    May 2012
    Cedar Rapids, Iowa
    so you pulled the fuse box?
  13. #13 Re: water pump replacement
    just slung it up out of the way, left all the wires hooked up.
    thats the bottom of it in the first pic.
  14. #14 Re: water pump replacement
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Overflow bottle on other side , 97 sc'ed. I do have the washer bottle on top.
    I live here. DirtDog's Avatar
    Jun 2012
    Heck when I did mine on my old 04 all I did was remove the serpentine belt. Did move anything else
    Sent from my DROID RAZR using Tapatalk 2
  1. Replies: 5
    Last Post: 12-15-2012, 07:05 PM
  2. 04 GT2 Water pump replacement
    By apok in forum Engine
    Last Post: 07-24-2012, 06:27 AM
  3. Water pump replacement
    By Ophidia in forum General Tech Discussion
    Last Post: 04-10-2012, 08:05 AM
  4. Water Pump replacement
    By Reddcurrlz in forum General Tech Discussion
    Last Post: 02-25-2011, 04:07 PM
  5. Radiator and Water Pump replacement 95 Prix SE Coupe
    By Soultempter in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-20-2009, 12:08 AM
