Thread: I need antifreeze help quick!
Results 1 to 12 of 12
  1. #1 I need antifreeze help quick!
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    I wasn't thinking when I changed my thermostat today and put green universal antifreeze in. Don't ask why I didn't think it was a bad idea. Is universal really universal? I had dexcool in it before I changed it. I realize that I only changed half of the liquid when I drained the radiator. Is it a problem or did I basically just change the color of the liquid. I just need to know that it is not going to mess up my car.
    silver 2003 Grand Prix GT List is on it's way to be updated
  2. #2 Re: I need antifreeze help quick!
    Well you can't mix dexcool and green/yellow universal coolant, it will sludge up and become nasty.
  3. #3 Re: I need antifreeze help quick!
    Nov 2008
    Ok so now what do I do? I have to drive 200 miles tomorrow. Will it sludge up before then?
  4. #4 Re: I need antifreeze help quick!
    SWPA
    Flush it. Refill with green.
  5. #5 Re: I need antifreeze help quick!
    In 200 miles not likely, but can turn a nasty color from getting mixed in.
    How much did you put in?
    If you had time now, you can trying doing a quick coolant flush and refill with dexcool.
  6. #6 Re: I need antifreeze help quick!
    Nov 2008
    How do you flush it? What's the best way to do that?
  7. #7 Re: I need antifreeze help quick!
    I pull the upper rad hose with the engine warm and the thermostat open and just run a garden hose in there until clear water comes out of the thermostat housing. Then drive it for a little bit and do it again. Then pull the lower hose and then refill with coolant.
  8. #8 Re: I need antifreeze help quick!
    doing this with the t stat out is much faster, only so much comes out when the t stat opens, when the cold hose water get to the t stat, it shuts again, so it s like 1/2 gallon spurts.
  9. #9 Re: I need antifreeze help quick!
    Nov 2008
    Sooooo dex or universal in the refill
  10. #10 Re: I need antifreeze help quick!
    green in the refill
  11. #11 Re: I need antifreeze help quick!
    Nov 2008
    How many gal does the car hold total?
  12. #12 Re: I need antifreeze help quick!
    a bout 3.
    flush it till clear water comes out the upper hose, then take the hose out, aka turn the water off. then run the car till water stops coming out of the upper hose, turn off the engine, then hook it all back up, hose, t stat, and dump 1 gallon of full strength coolant in the rad, top it off with water, run it fill it, bleed it.
  1. oil in antifreeze
    By lorello in forum General Grand Prix Discussion
    Last Post: 06-19-2012, 09:55 AM
  2. Oil In Antifreeze
    By zackp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2012, 01:34 AM
  3. LIM antifreeze leak
    By 2004GrandPrixGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-28-2012, 10:49 PM
  4. Idk, antifreeze?
    By Tha Ghost in forum General Tech Discussion
    Last Post: 01-30-2011, 09:49 PM
  5. Smelling antifreeze
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 11:06 PM
