Thread: Need a lil help w the GXP
Results 1 to 16 of 16
  1. #1 Need a lil help w the GXP
    Wichita
    Wasn't too sure where to post this so I'm posting it here. Recently I got a code for a bad TPS and the front end if the car started to shake, like the wheels were loose. I know the bad TPS means I'll most likely be replacing the TB but I'm not too sure what's causing the shaking. Any thoughts, comments, suggestions?
    I live here. DirtDog's Avatar
    Jun 2012
    Mine did a shake thing when the cv half shaft was bad.
    Sent from my pager using Morse code. ... .. ... ....
  3. #3 Re: Need a lil help w the GXP
    Wichita
    I'll hafta see if the cv shafts are covered under the cars warranty. That'd Save me a couple bucks. if that's the issue. If not, cv axles are kinda cheap.
    Jun 2012
    Are they still the original ones from factory? I have 47xxx miles on my car and my passenger one the boot busted. And it didn't have any grease left and started acting very similar to what u described above
    Pretty sure cv axles are under that normal maintenance thing at least I had to come out of pocket when I had a warranty.
    04 Comp G.
  6. #6 Re: Need a lil help w the GXP
    Wichita
    I'm sure they are the originals.
    Jun 2012
    Get em checked out and let us know of it solves ur problem.
  8. #8 Re: Need a lil help w the GXP
    Wichita
    The cv axles for the GXP & GTP are the same aren't they? Cuz the axles are way more expensive for the GXP for some reason.
    Jun 2012
    The drivers side is I believe but I'm not for sure bout passenger side. If they have em both in stock at auto parts store compare them. If the gtp has the HD tranny then they should be same. If not HD tranny then different
  10. #10 Re: Need a lil help w the GXP
    Wichita
    They are the exact same tranny.
    Jun 2012
    Should be same...dunno why price difference is there. Just compare the old shaft with new one before u install. Make sure they match
  12. #12 Re: Need a lil help w the GXP
    Wichita
    I will. But before I go buying anything I'll see if the dealership will cover this under the powertrain warranty.
    Jun 2012
    They should....its part of it
  14. #14 Re: Need a lil help w the GXP
    GTP Level Member
    Sep 2011
    Motown
    the shaking could be something as simple as a lost wheel weight..
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  15. #15 Re: Need a lil help w the GXP
    GT Level Member GMCustomerService's Avatar
    Michigan
    SDGTP99,
    Was your dealer able to assist you further with this?
    Let me know if you have any additional questions.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  16. #16 Re: Need a lil help w the GXP
    Wichita
    Going to the dealership Monday. Hopefully it dosent break before then
gxp, lil
