Thread: 99 blowing cold air
Results 1 to 9 of 9
  1. #1 99 blowing cold air
    Jun 2012
    Golden Eagle, IL
    ok so i have had the car for a while and always wondered why it would never get over 180 degrees. Bought a new t-stat and flushed the rad, filled it with prestone any make, any model coolant and now i have no hot air at all. Before i had a little bit, but now none. The hoses going to the heater core are both cold.
  2. #2 Re: 99 blowing cold air
    Back flush the heat core with a garden hose, then fill the LIM with coolant first, put in thermostat and housing and leave the rad cap on and bleed the cooling system with a bleeder on top of the thermostat housing.
  3. #3 Re: 99 blowing cold air
    Jun 2012
    Golden Eagle, IL
    witch hose is in and witch is out on the heater core
  4. #4 Re: 99 blowing cold air
    take both hoses off, it does not matter which hose you put the garden hose to to flush and fill it up.
  5. #5 Re: 99 blowing cold air
    Jun 2012
    Golden Eagle, IL
    ok so i have hot air now. the temp gauge is going crazy tho, it rises to about 200 and then will drop off to 180 or so. what would cause that
  6. #6 Re: 99 blowing cold air
    these cars tenp always go up and down, sitting they run warm, moving they cool right down.
    as long as your not over heating its ok.
  7. #7 Re: 99 blowing cold air
    Jun 2012
    Golden Eagle, IL
    ok thanks, it just freaked me out a little
  8. #8 Re: 99 blowing cold air
    Did you bleed the cooling system of air all the way?
    Air pockets can cause the temp gauge to read all over. Once a 195 thermostat is opened up, temp changes shouldnt be more than 5-10ยบ unless sitting in heavy traffic on a hot day.
  9. #9 Re: 99 blowing cold air
    Jun 2012
    Golden Eagle, IL
    thats prolly it, i will try to bleed tomorrow, got a basketball game today
  1. Heater blowing cold air
    By lawadm1 in forum General Grand Prix Discussion
    Last Post: 11-06-2012, 07:35 AM
  2. A/C not blowing cold
    By draines in forum General Tech Discussion
    Last Post: 06-21-2012, 10:03 AM
  3. Cold air blowing and overheating
    By dj2011 in forum General Tech Discussion
    Last Post: 03-05-2012, 05:25 AM
  4. Overheat and blowing cold air
    By skibender in forum General Tech Discussion
    Last Post: 12-22-2010, 08:57 PM
  5. Blowing cold air
    By tracker1925 in forum General Tech Discussion
    Last Post: 12-11-2010, 06:41 AM
