Thread: odd series of events...
Results 1 to 14 of 14
  1. #1 odd series of events...
    SE Level Member Elrodd384's Avatar
    Mar 2012
    Fort Campbell, KY
    So today I got an Evap code, stopped to check the gas cap and decided I'd fill up. The pump wouldn't keep going like my Tank was full so I took it out and heard a hissing sound like a vacuum leak from the fill tube. Turned the key on then off and it pumped fine. Then I started the car and checked my i/m readiness on my torque app and got catalyst, O2 sensor, O2 heater, and evap system incompletes...any ideas???
  2. #2 Re: odd series of events...
    It's Slow LS1GTP's Avatar
    Sep 2012
    Clarkston, MI
    I have the opposite problem, when I leave the pump running by itself, the gas will overflow if I don't click it off myself. Remember someone saying something about a solenoid.
    Not sure on the rest of your issues.
  3. #3 Re: odd series of events...
    GTP Level Member joe0813's Avatar
    Boston, MA
    not to jack the thread but how that torque app? and what adapter do you need to run it??
  4. #4 Re: odd series of events...
  5. #5 Re: odd series of events...
    Boston, MA
    thanks, i just ordered one.... and hows your filler neck? they have check valves in there that might be bad
  6. #6 Re: odd series of events...
    Mar 2012
    Fort Campbell, KY
    I'm not sure, I know there's a vacuum there, but why would that **** the pump off and what does it have to do with the O2 system?
  7. #7 Re: odd series of events...
    Boston, MA
    you could always check the vent tube... if its clogged it will keep cutting the pump off... and do you remember what codes you have?
  8. #8 Re: odd series of events...
    Boston, MA
    if the check valve is stuck it will make it so no more gas gets pumped in... thats why when you fill your tank it automatically shuts off... and i have no clue why that would affect your O2... maybe you have two different issues.
  9. #9 Re: odd series of events...
    Mar 2012
    Fort Campbell, KY
    P0440 was the only code
  10. #10 Re: odd series of events...
    Boston, MA
    Id check the vent tube
  11. #11 Re: odd series of events...
    Apr 2012
    Goderich, Ontario
    There is a filter/cartridge in the vent tube that needs changed.
  12. #12 Re: odd series of events...
    Jun 2012
    Golden Eagle, IL
    the evap can on top of the gas tank might be pluged up also
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I've got the same problem. I've changed the purge and vent solenoids. I've confirmed they are working properly with my tech2. I wasn't aware there was anything in the filler neck. Something is clogged
    Sent using my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
    Ohio
    All I ever did when that happened was pop the hood, and depress the valve on the evap line. Worked every time
  1. 2004 series 3 3800 swap to 1998 series 2 car?
    By carpenterbronco in forum General Tech Discussion
    Last Post: 04-13-2010, 11:12 PM
  2. My series of unfortunate events
    By Golman76 in forum The Rant Forum
    Last Post: 02-26-2010, 02:38 PM
  3. Events
    By Dedlydragoness in forum Shows and Events
    Last Post: 12-01-2009, 08:32 AM
  4. up coming events
    By blown gt in forum Northeast
    Last Post: 08-01-2009, 11:19 AM
  5. drift events
    By 1998xGTP in forum Off Topic Discussion
    Last Post: 06-19-2009, 06:06 PM
