Thread: Rattling/Vibration noise front driver side
Results 1 to 8 of 8
TBrill20 Rattling/Vibration noise... 12-22-2012, 11:49 AM
matt5112 One thread per topic 12-22-2012, 11:53 AM
sco77 Re: Rattling/Vibration noise... 12-22-2012, 01:58 PM
dsmuts Re: Rattling/Vibration noise... 12-22-2012, 02:05 PM
TBrill20 Re: Rattling/Vibration noise... 12-22-2012, 02:53 PM
sco77 Re: Rattling/Vibration noise... 12-22-2012, 04:29 PM
TBrill20 Re: Rattling/Vibration noise... 12-22-2012, 04:45 PM
dsmuts Re: Rattling/Vibration noise... 12-22-2012, 04:53 PM
  1. #1 Rattling/Vibration noise front driver side
    Dec 2012
    West Virginia
    I was wondering if anyone could tell me what is causing a noise. The noise sounds like metal vibrating or rattling against other metal. or maybe some rocks on a cookie sheet. It makes the noise when I accelerate fast and my RPMS shoot up. It does it most often when accelerating up a hill. It sounds like it is around my front driver side around the tire or under the hood. I cant pin point it very well. Thanks for anyone with suggestions/answers.
  3. #3 Re: Rattling/Vibration noise front driver side
    SE Level Member sco77's Avatar
    MD
    Could be a loose flexplate bolts, or valvetrain noise resonating through the intake.
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
  4. #4 Re: Rattling/Vibration noise front driver side
    Cv joint maybe
  5. #5 Re: Rattling/Vibration noise front driver side
    Dec 2012
    West Virginia
    I just put an after market chrome intake on it. i hadn't heard it before I put that aftermarket intake on it. what could i do to fix the noise?
  6. #6 Re: Rattling/Vibration noise front driver side
    MD
    Quote Originally Posted by TBrill20 View Post
    Might sound kind of obvious, but is the filter secured from the body? put some type of padding in the area where it may be touching something.
    As I said above an intake can allow you to hear valvetrain noise. Can be from worn or loose rockers, valve guides, timing chain, etc.
    98 GTP - Retired
  7. #7 Re: Rattling/Vibration noise front driver side
    Dec 2012
    West Virginia
    yeah its secured good with hose clamps. there is rubber between the clamps and the metal intake tube. is my best bet to take it to an auto shop and have them drive it and listen to the noise and attempt to fix it? im thinking it may be a heat shield but im not sure where they are all located and how to get to them. it kinda sounds like a loose screw rattling in a heat shield.
  8. #8 Re: Rattling/Vibration noise front driver side
    Take a pic of your intake
  1. Rattling noise from the front of engine
    By tjhgtp86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-16-2010, 10:10 AM
  2. Driver-side Vibration
    By spcguy88 in forum General Tech Discussion
    Last Post: 02-15-2010, 06:07 PM
  3. Vibration driver side, how to fix?
    By gmoney25 in forum General Tech Discussion
    Last Post: 09-25-2009, 09:31 AM
  4. Noise in Front Driver-Side Tire Well
    By PsychOut in forum General Tech Discussion
    Last Post: 09-05-2009, 08:43 PM
