Thread: 01 GP, won't idle and now transmission won't shift? HELP
Results 1 to 3 of 3
  1. #1 01 GP, won't idle and now transmission won't shift? HELP
    Donating Users ARFF22's Avatar
    NEW YORK
    Have an 01 GT with approximately 10k miles on a new engine with a Z7 kit on it. Car has been driving fine for a year. Last week the car would not hold an idle and stalls. At idle the engine just cycles up and down and finally dies. Unplugged the IAC and the car would idle, but would then throw a P0507 code. Replaced IAC, no change. Replaced MAF, no change. Replaced PCV, no change. I'm assuming a vacuum leak but there is nothing obvious. Was driving the car without to much of an issue for about a week, but now, my speedo is haphazardly working, which, I'm assuming, is causing my transmission to not shift properly if at all! I basically have first gear, when the speedo begins to read, it shifts up, then the speed dies and it shifts back to first. Any assistance would be greatly appreciated!
  2. #2 Re: 01 GP, won't idle and now transmission won't shift? HELP
    St. Louis
    Check the wire harness connector to the trans and make sure it is clean and tight.
  3. #3 Re: 01 GP, won't idle and now transmission won't shift? HELP
    NEW YORK
    Finally got the poor idle stalling issue all resolved, ended up being just a blown fuse (#21) under the hood. Who knew it would be so aggravating yet so simple! Still working on the transmission issue, I'm assuming it is the VSS?
  1. High Idle and Shift Problem
    By joeysavoie in forum General Tech Discussion
    Last Post: 02-10-2013, 07:13 PM
  2. transmission won't shift automatically
    By crazybrownklick in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-25-2012, 03:07 PM
  3. Transmission will not shift into overdrive
    By JennysGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-21-2012, 10:37 PM
  4. Transmission wont shift out of 1st
    By topswap in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-22-2010, 08:42 PM
  5. Tap Shift Transmission.
    By isucyclones3 in forum General Tech Discussion
    Last Post: 02-08-2009, 09:36 PM
