okay so a few weeks back my heater was staying on after i removed the key from the ignition. I then did some research and found the TSB and replaced the blower motor resistor and installed the 330 uf capacitor.
Now recently when i start the car and turn the heat on, it doesn't matter if its the air or heat, nothing works. Usually after about 10 or 15 minutes of driving the heat will kick on. Sometimes the heat doesn't kick on at all.
I read somewhere that the ignition switch? or possibly the ignition wiring? any help would be appreciated
Thanks Chris
