Thread: Day time running lamps
Results 1 to 15 of 15
Dohner Day time running lamps 08-14-2008, 09:51 PM
Rocket468 Re: Day time running lamps 08-14-2008, 10:46 PM
Dohner Re: Day time running lamps 08-15-2008, 09:27 PM
Preotic Re: Day time running lamps 08-16-2008, 10:00 AM
pelon713 Re: Day time running lamps 10-07-2008, 01:05 PM
Warhellride Re: Day time running lamps 10-08-2008, 05:07 PM
Dohner Re: Day time running lamps 10-09-2008, 05:20 PM
Dohner Re: Day time running lamps 10-08-2008, 09:32 PM
Street Wolf Re: Day time running lamps 10-08-2008, 09:44 PM
speedemongtp Re: Day time running lamps 10-09-2008, 05:51 PM
BackInBlack Re: Day time running lamps 10-09-2008, 06:19 PM
njbrain Re: Day time running lamps 10-09-2008, 07:14 PM
Dohner Re: Day time running lamps 10-10-2008, 09:04 PM
BackInBlack Re: Day time running lamps 10-12-2008, 04:33 PM
  1. #1 Day time running lamps
    GT Level Member Dohner's Avatar
    Montpelier
    Is their anyway to get these off other than pulling the fuse caz that makes a funny noise under the dash when i do that. I was wondering a way to do it to make them stay off i like the look of the car with no lights on. I know i can turn the switch between parking lights and headlights and that will shut them off but i still have the parking lights on. Let me know thanks.
  2. #2 Re: Day time running lamps
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    you pulling the fuse or the diode ? Should not get any noise.
    My EX wifes other car is a broom.
  3. #3 Re: Day time running lamps
    Montpelier
    Ok the last time I pulled the fuse it made a sound that sounded like the turn signal flasher under the steering wheel. I will try it again soon.
  4. #4 Re: Day time running lamps
    GT Level Member Preotic's Avatar
    Missoula, MT
    I believe you have to put a certain resistor in the sensor in the dash right by the windshield. Contact Back in Black he should know. I'm not sure if he's made it over here but you can always try him at Clubgp.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  5. #5 Re: Day time running lamps
    Oct 2008
    houston
    I have a 2002 Grand Prix my problem is that when I turn on my AC my headlights and info center go out. Can any one please help me Thanks
  6. #6 Re: Day time running lamps
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    ^^I'd recommend starting your own thread for a separate question. You'll get more responses, and it won't clutter up someone else's thread.
    To disable DRL's. Pulling the fuse only works in the older model years (I don't remember exactly which years). To disable them in the newer cars, all you have to do is unplug the DRL diode in the dash. Open the driver side door, then remove the little panel on the side of the dash. You'll see a black module with a big heat sink. Unplug the connector running to this module, and your DRL's will be disabled.
    The resistor that Preotic is talking about is to disable the twilight sentinel auto headlights). In the center of the dash, there's a panel with two holes in it. One hole has a red LED (flashes to make people think you have an alarm), and the other hole is for the photosensor for the twilight sentinel. Gently pry up this panel, and unplug the sensor. Replace it with a 470 ohm resistor 470 ohm. You can just slide the resistor into the connector, and use electrical tape to hold it in.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  7. #7 Re: Day time running lamps
    Montpelier
    Quote Originally Posted by Warhellride View Post
    IN the last paragraph here it says the Twilight Sentinel and how you can get diff. ohm resistors.
  8. #8 Re: Day time running lamps
    Montpelier
    Ok now if i unplug the sensor on the drivers side i dont have to mess with the twilight thing in the dash do I ?
  9. #9 Re: Day time running lamps
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by Dohner View Post
    What 'twilight' thing on the dash?
  10. #10 Re: Day time running lamps
    Montpelier
    Warhellride what head lights and fog lights do you have.
  11. #11 Re: Day time running lamps
    Ohio
    00 GTP demodded and forsale
  12. #12 Re: Day time running lamps
    GT Level Member BackInBlack's Avatar
    Vermont
    See my web site...
    The GPs are long gone...
  13. #13 Re: Day time running lamps
    GT Level Member njbrain's Avatar
    Rhinelander WI
    Listen to Black, he really knows his stuff.
  14. #14 Re: Day time running lamps
    Montpelier
    Ok i have it figured out they are off and the night lights still come on at dusk. NOw i have a question for you Back In Black. How dose that whole head light wiring upgrade work i am stuck on where you cut the stock wiring.
  15. #15 Re: Day time running lamps
    Vermont
    You actually DON'T cut any stock wiring with the harness. I try and design most of my modifications that way. Very hard to repair wiring that has been cut and left out in the elements...
    All you need is 2 relays, 2 dead 9007 bulbs and 2 9007 or 9004 pigtails. 3rd gen Dodge Caravans make excellent relay donors and old Ford Taurus's make good donors for bulbs and sockets, as they're really easy to take out. The fuse is easy. Grab a power window or power seat self-resetting circuit breaker from almost any car. Has 1/4" spade lugs for easy installation...
  1. How to disable my day time running lights ??
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2010, 08:54 PM
  2. Time Running Out Klms Need To Know Things
    By GAGT+GP-OWNER in forum General Tech Discussion
    Last Post: 11-19-2008, 09:28 AM
  3. Fixing leaking corner lights, through lamps.
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 04-21-2008, 09:39 PM
  4. looking for new fog lamps
    By ayman in forum Visual/Body Modifications
    Last Post: 04-03-2008, 11:30 AM
  5. L.E.D Tail lamps
    By Dohner in forum Visual/Body Modifications
    Last Post: 02-09-2008, 05:34 PM
