Thread: Cross-threaded radiator cap
Results 1 to 10 of 10
  1. #1 Cross-threaded radiator cap
    SE Level Member GXPrunner06's Avatar
    Jan 2013
    Romulus, MI
    Own a 06 gp gxp. It has the hard plastic rad cap. I try to loosen it and it loosens then tightens back up. If I go the other way it does the same thing. How do I get this off?......Hit it with a hammer? Also how much is a new one?
  2. #2 Re: Cross-threaded radiator cap
    Push down while you turn and it will come off.
  3. #3 Re: Cross-threaded radiator cap
    Jan 2013
    Romulus, MI
    Well.....I have tried that and it won't come off. Is there a way to pry it off? Only reason I want this off is because I would like to do a flush
  4. #4 Re: Cross-threaded radiator cap
    GT Level Member jlgp2007nc's Avatar
    Sep 2012
    North Carolina
    Don't pry. You'll break it and end up having to replace the radiator. There's a special tool you can buy for it.
    Or...Spray some silicone spray on it...let it soak...push down and twist like your life depends on it with a wrag or something so your don't hurt yourself. No pb blaster. Petroleum products and plastics don't go well together.
  5. #5 Re: Cross-threaded radiator cap
    Jan 2013
    Romulus, MI
    i have 06 GXP the caps not on the radiator its on the engine which I assume is aluminum.
  6. #6 Re: Cross-threaded radiator cap
    It's not like the 04+? They have the plastic cap on the radiator.
  7. #7 Re: Cross-threaded radiator cap
    GXP's have like a sealed rad per say, it just has hoses coming to and from it, there is no cap.
    The "rad cap" is on the pulley side of the motor on top near the PS pump I think, its just a screw on style.
    Every time I've removed one I just push down and turn.
    If it still doesnt want to move, grab a pair of channel locks and twist it off.
  8. #8 Re: Cross-threaded radiator cap
    Ohio
    Remember, cross threads are better than no threads
  9. #9 Re: Cross-threaded radiator cap
    Sep 2012
    North Carolina
    1 cross thread is equivalent to 2 tubes of loctite.
  10. #10 Re: Cross-threaded radiator cap
    Yoga city
    i dont think its crossthreaded, when i first got my car checking fluild levels i had a hard time too. I would turn about half a turn it would get tight, once i would get past that is was fine. I do know of this. And the cap is at the top of the remotly mounted pump. cant miss it lol
  1. Cooler line pops out at radiator. Dealership says I need a new radiator?!?! Pic
    By nickbuol in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2013, 08:27 PM
  2. Replies: 28
    Last Post: 07-26-2012, 07:33 AM
  3. Nobody Canna Cross it
    Last Post: 08-22-2011, 08:34 AM
  4. Need help - is tensioner pulley reverse threaded??
    By chantspel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-07-2011, 03:51 PM
  5. Cross-Threaded a lug nut :(
    By cboth686 in forum Tires & Wheels
    Last Post: 03-20-2010, 06:32 AM
