Just finished replacing the fuel sending unit on the 01 GT. Access through the trunk, pump came out with no issues. The problem was in re-installing the locking ring over the fuel pump. I diddled, then fought, with this thing for hours trying to get it to engage all the tabs and rotate around to lock. The new gasket on the fuel pump was pretty plump and hard to push down into the tank opening. I made this "tool" to use to keep the locking ring pressed down so I could bang it with the drift and rotate it:
Just a piece of steel with holes tapped for 5/16-18 bolts. Tightening the bolts kept even pressure on the locking ring so I could tap it around with the drift and get it seated. I'll send it to anybody to needs it, just lemme know.
