Thread: Belts took out crank sensor now no start
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Belts took out crank sensor now no start
    Overland Park, KS
    Alright, after reading this: 3800 GM Ignition System Description and Operation I learned that the ignition module should be giving me spark during cranking if it's getting signal from the crank sensor independent of the pcm. I had both ignition modules I have checked (good) at O'Reilly's but I'll be taking them both somewhere else to be checked out tomorrow. If they both still check good I'm pulling the new crank sensor back out. It has to be bad.
    04 GTP Comp G, airbox cut, no cat or resonator
  2. #22 Re: Belts took out crank sensor now no start
    Grand Rapids, MI
    From what I understand, a bad ICM will test good even if it is not. So the best bet is to swap one in there that you know works, if you suspect that's the problem.
  3. #23 Re: Belts took out crank sensor now no start
    Overland Park, KS
    I think I'm on the right track now. I was convinced that my new crank sensor was DOA. Had previously checked the wiring and had continuity between connectors. So I replaced the sensor with a Borg Warner part. Still nothing. So, I decide to find a way to test to ignition module on the car. Part 1 -GM 3.8L Ignition Module Test and Crank Sensor Test (3X, 18X) Everything was checking out fine until I got to the 3x signal from the crank sensor. No signal to the ICM. The wire does have continuity but I can also light a test light touching it to + on the battery. I'm guessing that the light blue/white wire is grounded to the block or a bracket somewhere. I'll know tomorrow night. At least I'm getting an education on the ignition system...
  4. #24 Re: Belts took out crank sensor now no start
    Overland Park, KS
    Forgot to follow-up with this but figured I should put this out there to be sure someone doesn't make the same dumbass mistake I did. When I put the balancer back on apparently I didn't torque it down. Usually I just use the impact wrench and crank it down. This day was in the cold & dark, for whatever reason I never came back to torque it down. The triggers in the balancer were too far away from the crank sensor to make a signal which is why I was getting no spark or injectors firing. Fought wiring & testing the ICM forever before I finally let it sit & drove something else for awhile. Cranked the balancer down once I figured out that was it & it fired right up. It's a miracle! One of my dumbest mistakes ever...
  5. #25 Re: Belts took out crank sensor now no start
    Johnstown, NY
    Lol. We all do dumb things after a long day. It's the rushed feeling when you just want the thing running again. I've done some hairbrained things with cars in the past too. I think we all have.
  1. New guy from SD, Crank position sensor help.
    By Mak90 in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-15-2012, 09:14 AM
  2. 3 wire crank sensor vs 2 wire with 24x crank trigger
    By greenmachinegtp in forum PCM Tuning
    Last Post: 03-12-2012, 05:45 PM
  3. crank position sensor?
    By Mitchstrp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2011, 12:45 PM
  4. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  5. crank position sensor
    By vermsta in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-02-2008, 02:41 PM
