Thread: 2001 GP ABS/TRAC OFF Warning Lights Come On When Turning Right
Results 1 to 3 of 3
  1. #1 2001 GP ABS/TRAC OFF Warning Lights Come On When Turning Right
    Aug 2012
    Stonington, CT
    Has been happening fairly regularly of late, suspect a bad connection or damaged wiring at one of the front wheel speed sensors, based on when the lights are triggered on. I sometimes can trigger them on simply by cranking the steering wheel over to the right with the car fully stopped. Going to get under the car and check this out but wondering if any others have had this happen and what the outcome was.
  2. #2 Re: 2001 GP ABS/TRAC OFF Warning Lights Come On When Turning Right
    Aug 2012
    Stonington, CT
    I should add that I recently had the right front wheel bearing replaced, so that's pointing me to a connection/connector problem for the right front hub wheel speed sensor. I believe a Timken was used in the repair, so hopefully the new sensor is OK. The fact that I can trigger the lights with the car at full stop seems to be pointing to a momentary loss of connection to one of the sensors.
  3. #3 Re: 2001 GP ABS/TRAC OFF Warning Lights Come On When Turning Right
    tennessee
    timkens are good sh*t so id say its a bare wire grounding out
  1. ABS and Trac Off lights
    By Speedy1973 in forum General Tech Discussion
    Last Post: 02-11-2014, 08:33 AM
  2. hid fog lights not always turning on.
    By RyanL in forum Audio, Security & Visual Electronics
    Last Post: 12-03-2011, 01:25 PM
  3. Service trac / ABS lights on
    By Rocko48346 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2011, 04:03 PM
  4. ABS/Trac Off Lights on
    By trailshredder in forum Brakes/Suspension/Chassis
    Last Post: 10-31-2010, 05:59 PM
  5. ABS and trac off lights
    By probuilder1 in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2009, 06:31 AM
