Thread: Popping exhaust
Results 1 to 20 of 27
  1. #1 Popping exhaust
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    Hey guys so ever since I've been going to the new sams club gas station because it's like. 30 cheaper then the other stations near me.. So since then my exhaust pops when going over 4k in drive I also get a rotten egg smelling smell to.. No codes are thrown either I have an overkill pcm and thought that something could have got messed up with the tune so I pulled the negative cord on it to reset it.. That hasn't worked.. Any thoughts? Could it just be bad gas?
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  2. #2 Re: Popping exhaust
    when was your last tune up? wires?
    your cat could also be getting clogged.
  3. #3 Re: Popping exhaust
    rotten egg smell is clogged cat for sure.
  4. #4 Re: Popping exhaust
    Jun 2012
    Illinois
    Plugs were done 700 miles ago idk about wires.. If it was clogged wouldn't I know at all rpm?
  5. #5 Re: Popping exhaust
    it can cause misfires, which is what you are feeling when it wont go past 4,000 rpms, the cel light should be flashing when you do this, flashing light means stop doing what your doing.
    if you can get your car in the air, ramps, or jacks, hit the cat when its cold, listen for stuff rattling around inside it.if so its shot.
    you can also remove the o2 sensor in the upper rear manifold and see if moves better, yes this will cause a nice exhaust leak, but its a test only. or have the exhaust pressure tested.
  6. #6 Re: Popping exhaust
    Jun 2012
    Illinois
    No sel light
  7. #7 Re: Popping exhaust
    Jun 2012
    Illinois
    just filled up at mobil seems to bet getting better already
  8. #8 Re: Popping exhaust
    Jun 2012
    Illinois
    still popping just not nearly as bad. any other thoughts?
  9. #9 Re: Popping exhaust
    GTX Level Member Neil98gt's Avatar
    May 2011
    Kansas city
    its probably the cat, if it smells like rotten eggs, like stated before.
    When the car is cold jack it up and tap on the cat. If it rattles, its shot.
    and no it doesnt have to be from all rpm's for it to be the cat, just when it flows enough to cause a problem
    98 GT 2dr 116k, Sold
    07 Lexus ES350 Obsidian Black. Premium Plus package, sold
    2013 Hyundai Elantra GT
    2002 Grand Prix GT 4dr
  10. #10 Re: Popping exhaust
    Jun 2012
    Illinois
    just changed the fuel filter and did the taping on the cat... there was no rattling and the fuel filter didn't do a thing. still no codes thrown (been checking with just a regular obdII scanner) it will go above the rpms it just starts to "pop" around then... i am going to try the removing upper o2 sensor... can i go full throttle like that? and if that doesn't work what would u guys suggest to do?
  11. #11 Re: Popping exhaust
    I would check for vac leaks, that popping sound is a misfire.
  12. #12 Re: Popping exhaust
    Jun 2012
    Illinois
    I'm not exactly sure how to describe it really.... Would a video help? I wouldn't say it's really popping but more like a little stutter.
  13. #13 Re: Popping exhaust
    Yeah a video would help a lot if you could replicate the problem.
  14. #14 Re: Popping exhaust
    Jun 2012
    Illinois
    I took a video on my phone how do I upload it? Lol and I would more classify it as it hesitates.. And while being on the highway it did it a couple times when I got on it but then I did it a couple other times and no problems
  15. #15 Re: Popping exhaust
    upload it to a photobucket account, link it from there.
  16. #16 Re: Popping exhaust
    Jun 2012
    Illinois
    after many attemptes this is the only good one that you can tell.. you really have to listen for some reason it is nowhere near how bad it is in real life
    20121124_215426.mp4 video by chris01gtp | Photobucket
    hopefully this helps
  17. #17 Re: Popping exhaust
    I couldn't really hear anything but I'm on my phone
  18. #18 Re: Popping exhaust
    Jun 2012
    Illinois
    theres no problems with normal driving... just when i get on it
  19. #19 Re: Popping exhaust
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    no change when you pulled the o2 sensor? You described a popping sound at the start of this thread, is that what is on the video? Or is the hesitation something new? I'd start checking electrical...battery & alternator tested...check ground wires.
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  20. #20 Re: Popping exhaust
    Jun 2012
    Illinois
    haven't tried the o2 sensor and to be honest i really am not sure how to describe the sound id guess its more of a hesitating sound o a stutter r.. it defiantly seems like its exhaust related but i could be totally wrong. the battery is 4 years old so that could be it. also, when i check the o2 sensor, do i just drive it normally without the sensor in? like floor it an all and see if that does it?
    Thanks,
    Chris
  1. Popping
    By Kolton Lock in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2012, 05:23 PM
  2. popping noise
    By ohagen383 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-03-2011, 08:53 AM
  3. popping noise.
    By wlmrt6 in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2010, 11:52 PM
  4. Popping In Reverse
    By Chmanzi in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-20-2010, 11:00 PM
  5. popping sound
    By flatblackgtp16 in forum General Tech Discussion
    Last Post: 07-30-2009, 12:15 AM
