So, Story. My transmission dropped out of my 1999 Grand Prix SE. Just so Happened I had a 30K Mile transmission at work that I could have at no cost. So I swapped it in. It was out of a 98 Buick Park Avenue.
As I see it. It has 3.03 Gears in it. Where as my Factory transmission has 3.29's. All is fine and dandy. Except one issue, The PCM Sees the transmission as its slipping due to the different gear ratio. Altho its not truly slipping. It is Pushing full line pressure to the solenoids. Almost as if it has a strong shift kit installed.
I can, And Have dealt with it for a while but. Out of curiosity. I attempted to use the PCM out of the Buick to see if it would work. Surprisingly my car started with the Buick PCM. Altho they were visually different the Connectors were the same. But the bad. My Grand prix was missing/Running on 2-3 Cylinders. And my fuel gauge read empty.
Is there anything I can do to use the Buick PCM. Or Anything I can do to my factory PCM to make it shift like it should? Kinda gets old slamming into gears. And being able to break traction going 60 on a wet road punching the gas.
