Thread: Which is my better spark plug option?
Results 1 to 13 of 13
  1. #1 Which is my better spark plug option?
    Sep 2011
    South Central PA
    Im currently running autolite 104's (mods are in my sig) and my question is should I stick with them or should I switch to ngk tr6's? I was talking to someone selling his built gtp on craigslist and he said to switch, as I am getting around 7* of KR at WOT. Should I take his advice or should I just stay with the 104's? Or should I go with something else?
    2000 Grand Prix GTP Daytona 500
    WBS PCM, 3.5 Pulley, 3'' DP into Magnaflow Hi Flow Cat, Powerlog, No resonator, Wizaraid Intake, ZZP Wires, AL 104's, 180 Stat, Poly Dogbone Bushings, Optima Yellow top battery
  2. #2 Re: Which is my better spark plug option?
    Swapping plugs is not going to get rid of 7* of knock.
    Ever.
    Sounds like that thing needs some better wires, headers, and a solid tune.
  3. #3 Re: Which is my better spark plug option?
    A plog and 3in downpipe should be plenty to run that 3.5.
    This KR problem could be many things. Not running the proper grade fuel, bad mounts causing the motor to move too much, I dont see a fuel pump rewire on your mod list, and that canned tune likely doesnt have the correct changes for those mods.
  4. #4 Re: Which is my better spark plug option?
    Not really.
    If these cars knock with headers on a 3.5" why would a PLOG/DP combo be any better?
    These cars are getting older and more tired...they knock easier and don't like being modded.
    On top of that, "Y" car might be able to run those mods...but "X" car can't.
    It needs headers and a solid, dialed in tune.
  5. #5 Re: Which is my better spark plug option?
    Sep 2011
    South Central PA
    I figured it needs a dyno tune rather then having the shelf tune it has now. I dont know of any places around here that tune these cars. Plus money is tight right now, and I am taking it easy on the car. I just didnt know if I could at least lower it some by changing plugs which is cheap enough.
    Ohio
    Look up the pa wbody syndicate on facebook. Plenty of people that will tune you. Get ahold of 2003ssei on here. His name is pat, and he is in the pa group. He's a good tuner.
  7. #7 Re: Which is my better spark plug option?
    Street tune > Dyno tune.
    All day everyday.
    Don't dyno tune it.
  8. #8 Re: Which is my better spark plug option?
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    just pulley down!
  9. #9 Re: Which is my better spark plug option?
    Pennsylvania
    Are your 104's copper or iridium? How many miles are on them? Spark plugs are not making 7*KR. I'm voting vac/exhaust leak/tune... Or you've had copper plugs in for more than 15k mi and they're worn out. Or out of gap.
  10. #10 Re: Which is my better spark plug option?
    Quote Originally Posted by 98buicksupercharged View Post
    just pulley down!
    I don't think this was the post you were looking for...
  11. #11 Re: Which is my better spark plug option?
    Sep 2011
    South Central PA
    They are copper plugs, got them on zzp website. They dont have 15k miles on them though, I replaced them this summer.
  12. #12 Re: Which is my better spark plug option?
    Pennsylvania
    Hm, let's start easy.
    Make sure you have no vacuum or exhaust leaks. Make sure your maf and throttlebody are clean.
    Go grab some cheap store-brand spark plug wires and try them.
    Next thing I'd suggest is maybe trying 605's instead of those 104's since you've only got a 3.5" pulley.
  13. #13 Re: Which is my better spark plug option?
    Sep 2011
    South Central PA
    When I get a chance, im going to pull some plugs to see how they are wearing to see if I need to replace them. Ill try new wires as well. And if I can, get a tune. haha
  1. Spark Plug Gap
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 10-14-2012, 09:57 AM
  2. which spark plug?
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2012, 07:39 PM
  3. Spark plug gap?
    By 91z in forum General Tech Discussion
    Last Post: 04-20-2011, 08:28 PM
  4. Spark plug
    By zildjian102 in forum General Tech Discussion
    Last Post: 03-01-2011, 02:48 AM
  5. Spark Plug Help
    By STP5593 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2010, 10:15 PM
