I moved my performance shift button to a red led rocker switch next to the heated seat button I wired the + to the 12 volt connector and the - to the ground connector on the switch I didn't connect the acc. connector for the led light the performance shift lights up and works fine on the D.I.C.. I read a forum where a guy said his "performance shift light on the D.I.C. doesn't work but the performance shift light on the I.P. works" now my I.P. light doesn't so I took the I.P. cluster out seen there was no bulb so I went to the auto parts store and bought one and replaced it; now this is where it gets weird I turned the performance shift button on and the led switch lit upand the performance shift light on the I.P. or D.I.C. didn't light up. Again
Can someone help me understand this?
