Thread: 98 throttle body on a 02?
Results 1 to 7 of 7
  1. #1 98 throttle body on a 02?
    GT Level Member cmal37's Avatar
    May 2011
    Tampa FL near USF
    I have an extra throttle body, I tore it down to polish it and realized it was off a 98, I was wondering if this will work with my 02 as long as i use a 98 Maf.
    I dont want to waste the time polishing it if it will not work.
    Thanks
    GMPP Struts, F body brakes, CAI, Ubend, resonator, and cat delete, 180tstat, SD headers, 3.4 Pulley, OverKill PCM,http://www.grandprixforums.net/my-bl...res-60017.html
    GT Level Member Utter99's Avatar
    Warsaw indiana
    It'll work if the mafs are the same but if I recall 98 and 02 are different mafs
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  3. #3 Re: 98 throttle body on a 02?
    May 2011
    Tampa FL near USF
    They are different. but if i put the 98 maf in my 02 will it work?
  4. #4 Re: 98 throttle body on a 02?
    No..won't fit properly.
  5. #5 Re: 98 throttle body on a 02?
    May 2011
    Tampa FL near USF
    like the wiring connection is different?
  6. #6 Re: 98 throttle body on a 02?
    MAF tables are different in a '02 PCM...you'd run lean enough to kick a vac leak code...ask me how I know.
  7. #7 Re: 98 throttle body on a 02?
    May 2011
    Tampa FL near USF
    Quote Originally Posted by blueguy91 View Post
    LOL, thanks. I guess ill just polish a supercharger as my winter project
  1. N* throttle body.
    By Erics00LS in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-11-2012, 01:32 PM
  2. LS1 or N* Throttle Body
    By 2000GTP2708 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2012, 08:19 AM
  3. Throttle body
    By apierce1289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-22-2011, 06:43 AM
