Thread: It's a GTP grenade...help...urgent
Results 1 to 8 of 8
  1. #1 It's a GTP grenade...help...urgent
    Nov 2012
    germantown,oh
    98 gtp spark plugs-new,plug wires-new,coil packs-new,icm-swapped for trialing purposes.
    No spark on coil pack that is supposed to fire cylinder 6 and 3...any ideas.
  2. #2 Re: It's a GTP grenade...help...urgent
    Modded for Maximum Slow burgundybullet's Avatar
    Menomonie, Wisconsin
    What are the coil packs that you replaced?
    1978 Oldmobile Cutlass Cruiser (crushed)
    2000 Grand Prix GT (Revived DD)
    2001 Grand Prix GTP Special Edition (Weekend Warrior)
  3. #3 Driving along and pop 2 cylinders with no fire.
    Nov 2012
    germantown,oh
  4. #4 Re: It's a GTP grenade...help...urgent
    Nov 2012
    germantown,oh
    Initially from OEM to MSD however since then I have moved them around and taken the OEM coil packs off another another vehicle.
  5. #5 Re: It's a GTP grenade...help...urgent
    Nov 2012
    germantown,oh
    My determination thus far is that whatever controls the connector fartherest back on the ICM is fried. However I don't know how to confirm this nor do I know if the PCM from 97 will run my 98.
  6. #6 Re: Driving along and pop 2 cylinders with no fire.
    St. Louis
    Check the wiring harness that connects to the ICM. Make sure all the wires are pushed into the connector all the way and are clean.
  7. #7 Re: It's a GTP grenade...help...urgent
    97 and 98 pcm's aren't compatible. The wiring is different on the connectors.
    merging.
  8. #8 Re: It's a GTP grenade...help...urgent
    Nov 2012
    germantown,oh
    Checked harness thoroughly cleaned and reinstalled all to no avail.
  1. URGENT What is this?!
    By PioneerGTP in forum General Tech Discussion
    Last Post: 10-09-2012, 04:49 PM
  2. Grenade pool
    By z3r0 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-28-2012, 10:15 AM
  3. Need Urgent Help
    By ahl395 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 03-18-2012, 11:50 PM
  4. Urgent help
    By milfadic in forum General Tech Discussion
    Last Post: 05-20-2010, 06:02 PM
  5. Urgent need of Help
    By Sunstone in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2008, 01:22 PM
