Thread: No Heat - checked the forums but still not sure what to check next
Results 1 to 4 of 4
  1. #1 No Heat - checked the forums but still not sure what to check next
    Oct 2012
    osakis, mn
    My daughter's 99 grand prix stopped blowing heat. The blower is not engaging on any speed. We pulled the blower, jumped it from the battery and it blows fine. tested the plug that goes into the blower and that also reads 13.9 amps on speeds 3&4, not 1,2 or 5. cleaned the connections, not sure what to test next. ignition or resistor or ? Seems like the blower should still engage on speeds 3 & 4 but it does not. Thanks
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    They arent that expensive. Id replace it first since it is bad. Could be an issue with the ground. With power on one side of the plug is there ground on the other? Just a thought.
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  3. #3 Re: No Heat - checked the forums but still not sure what to check next
    GT Level Member Tony Mendez's Avatar
    Aug 2012
    Somerset WI
    Quote Originally Posted by rperry435 View Post
    X2 on the ground
  4. #4 Re: No Heat - checked the forums but still not sure what to check next
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    You need to replace the blower motor resistor, very common issue on these cars.
  1. Checked tranny fluid and Ive got problems...
    By burgundybullet in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-28-2012, 07:07 PM
  2. new plugs 2 weeks ago - Re-checked them yesterday and....
    By hcokiid18 in forum General Tech Discussion
    Last Post: 11-16-2011, 12:12 AM
  3. Highway vibrations... (checked the usual)
    By Raviaan in forum Brakes/Suspension/Chassis
    Last Post: 09-22-2011, 11:24 PM
  4. What else should I get checked out?
    By Godfather in forum General Tech Discussion
    Last Post: 07-16-2011, 12:32 PM
  5. Checked out a 4dr GTP today...
    By bstuby in forum Off Topic Discussion
    Last Post: 03-31-2011, 12:37 AM
