Thread: Swapping out engines
Results 1 to 16 of 16
  1. #1 Swapping out engines
    Aug 2012
    Michigan
    About a week and half ago, someone ran a red light and totalled my '99 GTP. I have a '98 GT with about 140,000 miles that I was thinking about transplanting the GTP engine and trans into. Would it need the computer or wiring harness switched over as well? The GTP has no leaks and about 108,000 miles. The '98 leaks a little oil, but nothing major. I just don't know if it would be worth it money wise to do the swap. I would have to pay someone to do the work.
    Swapping out engines Attached Images
  2. #2 Re: Swapping out engines
    St. Louis
    You'd need the harness and GTP ECU for sure. Think one of the axles is a different length on the GTP as well, could be wrong. On whether or not its a good idea to swap, well, that's up to you. If you like the S'C then I say swap. If the GT is doing well right now then I'd just leave it be. Or you could just pull the engine/trans from the GTP whole and save it for a later date if the GT develops an issue.
  3. #3 Re: Swapping out engines
    Aug 2012
    Michigan
    I think I'll just wait like you said. Or find someone selling a good GTP body for cheap.
  4. #4 Re: Swapping out engines
    How bad off is that hood? It's the same color as my car
  5. #5 Re: Swapping out engines
    I live here. TLSheff's Avatar
    disconnect the hoses and wiring from the body on both cars. Lift both in the air. Drop both cradles (engine, trans, axles, etc) swap. Bolt back in, part other car out. Winning.
  6. #6 Re: Swapping out engines
    GT Level Member Toms04compg's Avatar
    Michigan
    Wolf look at detroit c list or grand rapids i just looked yesterday and saw what looked to be a nice gtp body no motor.
  7. #7 Re: Swapping out engines
    Aug 2012
    Michigan
    It's only cracked in one spot. I can take an up close pic if you want.
  8. #8 Re: Swapping out engines
    Wanna sell it? Close up pic would be nice
  9. #9 Re: Swapping out engines
    Aug 2012
    Michigan
    I'll take a picture tomorrow. I know one of the props came off though.
  10. #10 Re: Swapping out engines
    Easy swap. Move the motor, trans and passenger axle over. Keep your existing wiring harness. Add the boost control (or run to air) and change the connector for your map sensor (or buy an L32 one, same connector as the L36). Use the 99 GTP pcm to run the car while you have someone program you a 98 GTP PCM with your VIN in case the car ever needs to be emission tested or scanned by motor vehicle dept.
  11. #11 Re: Swapping out engines
    Aug 2012
    Michigan
    You have an email I can send the pics to?
  12. #12 Re: Swapping out engines
    dsmuts @ hotmail . com
  13. #13 Re: Swapping out engines
    SE Level Member PALMCASTER GT1's Avatar
    PALMDALE CA
    I was wondering the same thing about my 04gt , I got the money and was thinking of doing a complete swap to supercharged. , but was has to be changed to make it happen and what about the gages???? My car has 285000 and ready for some major work.
    04 GT1
  14. #14 Re: Swapping out engines
    Palm...
    Same stuff
  15. #15 Re: Swapping out engines
    PALMDALE CA
    Billboost.... will everything plug in with my wiring harness?? The boost gage too??? And the tranny has to be swapped also right??
    04 GT1
  16. #16 Re: Swapping out engines
    You'll have to add a couple of wires for stuff like the second map sensor and boost control. Overall though..it's cake. You don't "have" to swap the trans. You can program for the gearing as it would be different. You'll need a programming either way you slice it.
  1. Engines??
    By Speedy1973 in forum Off Topic Discussion
    Last Post: 05-18-2012, 10:00 PM
  2. How hot are l67 engines supposed to get?
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-12-2010, 09:02 PM
  3. What vin 1 engines.....
    Last Post: 06-16-2010, 08:03 PM
  4. Swapping engines
    By dbz09 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2009, 12:51 PM
  5. Some bling for these engines...
    By GR8racingfool in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-20-2008, 10:13 PM
