Thread: Grinding out struts to align your car??
Results 1 to 20 of 20
  1. #1 Grinding out struts to align your car??
    SE Level Member Bologna's Avatar
    Oct 2011
    Illinois
    I just took my car to a mechanic today and had him align my car. When I went to pick it up, he told me that it would be more than I was told earlier because he had to grind out all 4 struts to align my car properly. What the hell does that mean? I tried looking at my struts and I could see nothing different about them.
    Could someone explain to me what he did? What is that procedure?
    Thanks,
    Kyle
  2. #2 Re: Grinding out struts to align your car??
    he slotted your struts and used a camber bolt, so the wheels would be in spec.
  3. #3 Re: Grinding out struts to align your car??
    Oct 2011
    Illinois
    Sorry for my loss of terminology but what does it mean to slot my struts? Do you need to remove my struts in order to do so?
  4. #4 Re: Grinding out struts to align your car??
    all he did was make the hole bigger so the bolt could move more and get within the specs
    SMGPFC Member #10
  5. #5 Re: Grinding out struts to align your car??
    Pennsylvania
    He removed a bolt from the strut, ground the circular hole it was in into an oval, and that changed the angle of the strut.
  6. #6 Re: Grinding out struts to align your car??
    Oct 2011
    Illinois
    The hole, as in at the top of the struts where the nut is attached to the bolt?
  7. #7 Re: Grinding out struts to align your car??
    the bolt where the strut mounts to the knuckle. he took the bolt out, made the hole through the strut wider, so the wheel could move, to get it into spec. they did the right thing.
  8. #8 Re: Grinding out struts to align your car??
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Quote Originally Posted by Bologna View Post
    Nope definitely not that one.
  9. #9 Re: Grinding out struts to align your car??
    Pennsylvania
    ...where the nut is attached to the bolt... um. You know what, lemme just find you a picture.
  10. #10 Re: Grinding out struts to align your car??
    Oct 2011
    Illinois
    Alright, I was just wondering because it's impossible to get to the top of my 2 rear struts in my trunk, so if it involved him removing them then he definitely didn't and I have never heard of grinding them out before. Thanks for the information - it just seemed sketchy to me, especially since when I asked before I paid what it entailed the guy could barely tell me any information.
  11. #11 Re: Grinding out struts to align your car??
    Pennsylvania
  12. #12 Re: Grinding out struts to align your car??
    Pennsylvania
    That one's got a stock oval. Here's what your job should look like:
  13. #13 Re: Grinding out struts to align your car??
    Grand Rapids, MI
  14. #14 Re: Grinding out struts to align your car??
    Oct 2011
    Illinois
    Alright, thanks guys for the pictures - they really help.
    He said that he had to do it to all 4 though? That makes no sense to me, only one tire was unaligned and that was probably due to me unbolting my strut when I replaced m cv axel, tie rod end, and motor mount. What's the usually labor charge for it? He said he cut me a deal and only charged me for one strut but he actually did it to all four. He charged me $34 plus $70 for alignment.
    My Jeep only used to cost me $55 for alignment.
  15. #15 Re: Grinding out struts to align your car??
    Dec 2011
    Ontario,Canada
    You did good...your tires will thank him!
  16. #16 Re: Grinding out struts to align your car??
    your jeep is only the front wheels being aligned. the gp is all 4 wheels. toe in out, and camber. 70 is a fair price, and all 4 struts ground for 35 aint to bad either.
  17. #17 Re: Grinding out struts to align your car??
    Oct 2011
    Illinois
    I suppose you learn something new everyday, haha thanks guys.
  18. #18 Re: Grinding out struts to align your car??
    Pennsylvania
    Yeah, good price.
  19. #19 Re: Grinding out struts to align your car??
    I think he is kinda lying on the all 4 part.
    Did you get a print out of the BEFORE and AFTER alignment specs?
    Because it would take any mechanic some time to do all 4 with the amount of work involved.
    Just go outside when you get a chance and pull each wheel off one at a time and check the strut to verify if it was slotted.
    04 Comp G.
  1. Struts, or struts and springs?
    By vertebrate in forum General Tech Discussion
    Last Post: 08-14-2012, 07:23 AM
  2. How to align clock spring?
    By PurpleGuy in forum General Tech Discussion
    Last Post: 12-31-2011, 02:36 AM
  3. cam grinding
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-23-2010, 11:37 PM
  4. Grinding when braking?
    By LuckyBambu in forum Brakes/Suspension/Chassis
    Last Post: 02-15-2010, 11:54 AM
  5. Grinding Sound
    By Strype in forum General Tech Discussion
    Last Post: 09-02-2009, 01:15 PM
