Thread: Anyone identify what this plug is...
Results 1 to 12 of 12
  1. #1 Anyone identify what this plug is...
    GTX Level Member 97gtpjoe's Avatar
    Jan 2009
    Chandler, Arizona, United States
    Im a bit dumbfounded about what this plug is for, my 97 GTP is running great and no lights are coming on . Found this when I was doing oil pan removal it sits right below the power steering reservoir any help will be truly appreciated.
    Speed Daddy Headers, Open Cone, 3.4 MPS , AL605s , 180* Stat
  2. #2 Re: Anyone identify what this plug is...
    only thing i can think of is the rear knock sensor.
  3. #3 Re: Anyone identify what this plug is...
    Definately is. Reach up on the back of the ps pump and you should find the other end clipped to it. As long as the pump has never been off the engine. Otherwise..it'll be right in that same area where the green one and the one on the trans are in the wiring loom.
  4. #4 Re: Anyone identify what this plug is...
    Yoga city
    its a butt plug lol it gets knocked lol
  5. #5 Re: Anyone identify what this plug is...
    Jan 2009
    Thanks for the replies. I found this plug with another plug connected to it but the wires had been cut , I guess is time for a new knock sensor.
  6. #6 Re: Anyone identify what this plug is...
    the knock sensor is just that, the wires clip onto it, so you need a new harness to the knock sensor.
    if you can get the car in the air, look up between the oil and trans pan you can see the sensor in the side of the engine block. that way you can see if you have a plug on there now or not. maybe you can re solder the 2 ends together.
  7. #7 Re: Anyone identify what this plug is...
    Jan 2009
    I will have to check as soon as my car is back from the body shop. Wouldnt I get a check engine light on if that wasn't plugged in? The only thing that I could think of is the car has been reading like 10* of kr which would be impossible since I supported the car with all mods in order to eliminate knock after I dropped to a 3.4 pulley.
  8. #8 Re: Anyone identify what this plug is...
    i would think it would set a code if unhooked as well. the only way to know for sure is to look up at it and see if its got cut wires or nothing, or its hooked up correctly.
    you got one on the front of the block as well. same placement.
  9. #9 Re: Anyone identify what this plug is...
    This may be one of the codes that sets..and does not kick on the light.
    Many codes are setup this way.
  10. #10 Re: Anyone identify what this plug is...
    Jan 2009
    Could this be the reason why my KR on my gauge reacts like crazy?
  11. #11 Re: Anyone identify what this plug is...
    Not sure... You will find out though.
    Also.. looking again, I think I answered too quick and Scotty nailed it. Looks like that is the harness side of the wiring and the sensor side pigtail is missing. Can't really remember though... it's early.
  12. #12 Re: Anyone identify what this plug is...
    Jan 2009
    ok so I jacked up the car and the yes you guys where on target ,that connection goes to the rear knock sensor . The only problem that im having now is that the connector seen on the picture is hooked up to the rear know sensor where does the other end of the connection plug into?(it was stripped) Any help will be appreciated
  1. stock antenna plug to universal plug?
    By kind153 in forum Audio, Security & Visual Electronics
    Last Post: 01-08-2012, 10:25 PM
  2. Help identify this plug please
    By SarasotaGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-17-2011, 10:08 PM
  3. Identify this GTP
    By offroadfury6 in forum 04+ Specifics
    Last Post: 11-07-2009, 02:31 AM
  4. Help identify
    By ErichK in forum Visual/Body Modifications
    Last Post: 08-06-2009, 10:48 PM
