Thread: Car Stalls When Slowing Down?
Results 1 to 12 of 12
  1. #1 Car Stalls When Slowing Down?
    Aug 2011
    USA
    This has happened to my twice on a 97 Grand Prix GT. Whenever I exit the highway off ramp, the car just stalls. There is no sputtering and it just shuts down without me realizing it until I lose power steering. Is this an electrical or a fuel problem because I lose all power steering and the battery light does come on when the car shuts off. The car starts right back up and then seems to drive fine.
  2. #2 Re: Car Stalls When Slowing Down?
    Ohio
    how low was the gas?
    does the tach drop to zero before it stalls?
  3. #3 Re: Car Stalls When Slowing Down?
    Aug 2011
    USA
    The tank has been 1/4 to half full. I haven't noticed if the tachometer drops because I'm not even aware it stalls until I'm making the turn on the off ramp.
  4. #4 Re: Car Stalls When Slowing Down?
    Ohio
    hmm check engine light on?
  5. #5 Re: Car Stalls When Slowing Down?
    Aug 2011
    USA
    I'll add the same day this started happening my key will not remove from the ignition without using the release button under the column so I'm not sure if this is related.
  6. #6 Re: Car Stalls When Slowing Down?
    Aug 2011
    USA
    No check engine light.
  7. #7 Re: Car Stalls When Slowing Down?
    Ohio
    uhh yeah it probably is...
    sounds like ign switch..
    hopefully somebody will come in and correct me if i am wrong
  8. #8 Re: Car Stalls When Slowing Down?
    Aug 2011
    USA
    I'm thinking you are right too.
  9. #9 Re: Car Stalls When Slowing Down?
    FWIW you should expect all the lights on the dash to come on at a stall. Same as when you turn the key to on. It's the test of the lights.
  10. #10 Re: Car Stalls When Slowing Down?
    Aug 2011
    USA
    I'm pretty sure just the battery light comes on after it stalls.
  11. #11 Re: Car Stalls When Slowing Down?
    Aug 2011
    USA
    Would I lose power steering after a stall if it were a fuel type issue or does that only happen when it's an electrical or battery problem?
  12. #12 Re: Car Stalls When Slowing Down?
    No... these things come on when the igition is on and engine not running.
  1. GT Sputtering under load- only at idle and slowing down
    By Phil Becotte in forum General Tech Discussion
    Last Post: 10-24-2012, 12:04 PM
  2. unexplained engine slowing
    By joshuascompg in forum General Grand Prix Discussion
    Last Post: 07-06-2012, 11:26 PM
  3. Grinding noise when wheel turned sharply slowing down
    By steeck1 in forum Brakes/Suspension/Chassis
    Last Post: 12-13-2011, 04:19 PM
  4. Car stalls when hot
    By 98GTP PaceCar in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2010, 09:55 PM
  5. Vibration when slowing down
    By 03GPScottyd in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2008, 03:15 PM
