Is there a section that lets everybody know what all the abbreviations mean.
plog for one?
CAI= cold air intake
DP= down pipe......etc etc
Thanks
Dave
Also anyone in Alaska with a tuner?
plog for one?
Thanks
Dave
http://www.grandprixforums.net/f14/c...onyms-682.html
A plog is an abbreviation for Power Log, a front manifold/header/log ZZP sells that is much less restrictive than a ported front manifold.
dratz! you beat me to it!
I have a thrasher and i think if i had to choose i would prefer a Cold Air Inductions box or a Wizaired instead.
People seem to see much cooler temps on their wizaired then i do with my thrasher and the cold air inductions box is smiler to the wizaired just studier so therefore the cold air inductions box would be my choice.
some other common abbreviations you'll see
iat - intake air temperature
egr - exhaust gas recirculation
maf - mass airflow sensor
cps - crank position sensor
tps - throttle position sensor
kr - knock retard
rr - roller rocker
wb - wideband oxygen sensor
ltft - long term fuel trims
stft - short term fuel trim
ic - intercooler
mps - modular pulley system
pcm - powertrain control module (the car's computer)
ve - volumemetric efficiency
theres a bunch more im missing, but youre off to a good start
