Thread: Question about the over drive in my 07
Results 1 to 2 of 2
4thpontiac Question about the over drive... 10-20-2012, 10:54 PM
Fivefingerdeathpunch Re: Question about the over... 10-20-2012, 10:59 PM
  1. #1 Question about the over drive in my 07
    Oct 2012
    New York
    I just bought my 07 Grand Prix and like everything about the car. The only annoying thing about it is it really likes to quickly shift into overdrive. I have to push the pedal down almost halfway for it to finally shift out of overdrive when I start to go up a hill. Is this normal with this car? Does this engine have the active fuel management system which shuts off half the cylinders? My car is the base model Grand Prix.
  2. #2 Re: Question about the over drive in my 07
    During lets just say normal driving the trans shifts at 10-15 mph for 1-2, 25-35 mph for 2-3 and goes into 4th gear (overdrive) around 42-50 mph depending on throttle %.
    Its pretty normal to see the car lag when trying to go up a hill in 4th gear because its a highload gear, so most of the time the car will downshift or you'll have to press your foot down to make it drop into 3rd and make it up that hill.
    If you drive around in the city alot and most of your speeds are at or below 45-50 mph just keep the trans in 3 all the time, it'll stop that 4th gear lag around town and hilly metro areas.
  1. drive Shaft Question
    By rvnwlf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-20-2012, 05:43 PM
  2. Shift from park to reverse or drive, quick question
    By calvin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-21-2011, 04:20 PM
  3. Right hand drive question..PLEASE HELP!!
    By juicestain100 in forum Off Topic Discussion
    Last Post: 06-13-2010, 12:54 AM
  4. Final drive ratio question
    By 07CrimsonGT in forum General Tech Discussion
    Last Post: 08-11-2009, 05:58 PM
  5. Front wheel drive VS rear wheel drive.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-16-2008, 07:23 PM
