Thread: actuator or climate control
Results 1 to 2 of 2
  1. #1 actuator or climate control
    GT Level Member chicagochuck's Avatar
    Aug 2012
    Chicago
    I have the Manuel dual climate controls. I can hear the actuators working when I adjust the controls.
    Maybe this is a no brainer but I just want to make sure... most of the time,I was getting no heat on the driver-side. The passenger side works fine. At given times the heat would blow on the driver-side and if I turned it to cold and back to warm it would blow heat for a few seconds. Come to find out the lever on the control for the driver-side is very very sensitive. I can touch it and I will hear the actuator and I'm sure it responds to bumps and turns in the rode.
    I guess changing the climate control would be a lot easier then the actuator...so unless I get a concrete resolution that will be done first.
  2. #2 Re: actuator or climate control
    Sep 2012
    Dealership
    Definitely sounds like, maybe a slight short in that side lever. Especially if you can get an heater control from the junk yard cheap. I would go that route, changing that actuator is a lot more detailed.
  1. Climate control
    By 02Prix in forum Audio, Security & Visual Electronics
    Last Post: 05-14-2011, 12:08 PM
  2. Climate Control
    By GrandprixGearhead in forum General Tech Discussion
    Last Post: 10-30-2009, 11:47 AM
  3. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
