Thread: My L32 Swap Build Thread (20k mile update!)
Page 4 of 4 FirstFirst ... 234
Results 61 to 66 of 66
  1. #61 Re: My L32 Swap Build Thread
    GT Level Member RivMan's Avatar
    Oct 2012
    Pinckney, MI
    10,000 mile update!
    New Suspension:
    Excel-G 339015 Front Struts (06+ Style, FE4 Spec)
    Excel-G 339148 Rear Struts (06+ Style, FE4 Spec)
    Stock CompG Springs
    Monroe Strut Mounts
    Stock CompG Rear Swaybar
    Dorman Front Swaybar
    06+ Style LCA's
    Timkin Wheel Hubs at all 4 corners
    New headunit: Pioneer AVH-X3500BHS
    New Steering:
    New Rack / Pinion
    New Inner and outer tie rods
    New Power Steering Pump
    New Power Steering Return Line (Rusted out and leaked, causing the above to fail)
    New Brakes:
    Brakemotive Drilled / Slotted front and rear brakes
    New Tires:
    Dunlop Signatures
    Other:
    Replaced the Washer Fluid Level Sensor and connector (Corroded pins)
    To Do:
    Find / Install an 04 GTP ABS Module, the GT one installed is not compatible with the GTP PCM cal.
    Install the HUD from the CompG into the GT
    Install the 5 Channel Kicker Amp / Kicker QS 6.5's I have sitting here
    Track down the source of my EVAP DTC (Replaced the gas cap, no change)
    So far this car has cost a lot more then I planned, but as it stands, it's pretty much brand new!
    -Rob
    2004 GPGT - L32 Swap, CompG Trans - Click Here!
    1999 Regal - 300k miles: SOLD!
    1995 Riviera - L67 Swap, 12.9@107: SOLD!
    1999 GTP - 12.9@104: SOLD!
  2. #62 Re: My L32 Swap Build Thread
    Jul 2013
    United States
    How much money did you have to put into this im getting a 1999 grand prix and want to swap the engine to a L32
  3. #63 Re: My L32 Swap Build Thread
    Oct 2012
    Pinckney, MI
    In total, I spent ~$6,000 on this thing. Between the two cars and engine / trans parts I was at about $4,000. I spent another $2,000 on suspension / steering parts.
    I figured out my EVAP DTC. Replaced / the purge canister behind the drivers side rear wheel. It was packed with dirt and not functioning. No more issue there!
    -Rob
  4. #64 Re: My L32 Swap Build Thread
    Oct 2012
    Pinckney, MI
    20,000 mile update!
    As of this morning, this swap is finally 100% complete. I was able to pickup a 2004 GTP ABS module from Morad and install it. That fixed my TCS issue and the system works properly now! No DTCs, No warning lights, 100% factory functioning car!
    Since my last update, I tossed the Dunlops in the trash and picked up some Michelin Defender tires, 100% better then the Dunlops.
    Still to do is install the HUD from the CompG, other then that, I think this thing is good to go!
    Lifetime MPG Average: 22.4 MPG
    Maximum MPG (Road Trip) 29.08 MPG
    -Rob
  5. #65 Re: My L32 Swap Build Thread (20k mile update!)
    Sweet!
  6. #66 Re: My L32 Swap Build Thread (20k mile update!)
    Oct 2012
    Pinckney, MI
    Finally got the HUD Installed!
    The alignment is a bit off (Sits too far to the left) but I think that's because I didn't have any bolts to attach it, just zip tied it into place. I'll be fixing that as soon as I make it up to my shop to pickup the fasteners for it.
    -Rob
  1. My $800 GTP build thread!
    By Pittman06 in forum General Tech Discussion
    Last Post: 04-23-2013, 11:53 AM
  2. My 98 GT turbo build thread!
    By deadsnake in forum Turbo
    Last Post: 10-27-2012, 10:45 PM
  3. Regenesis: The Build Thread
    By MoarkatsINmuhtrailer in forum Members Rides
    Last Post: 03-05-2012, 12:42 AM
  4. Project 91 Firebird Build Thread
    By Lsick7 in forum Off Topic Discussion
    Last Post: 07-12-2010, 02:31 PM
  5. The new guy: Matto's Project build thread!
    By Matto211 in forum General Tech Discussion
    Last Post: 01-10-2009, 07:47 PM
