Thread: rear O2 for U bent delete
Results 1 to 2 of 2
SofaKingCdn rear O2 for U bent delete 10-03-2008, 04:07 AM
stlmo_gtp Re: rear O2 for U bent delete 10-04-2008, 08:59 PM
  1. #1 rear O2 for U bent delete
    Manitoba Canada
    I'm looking to get some exhaust work done soon (U-Bent and res delete, the usual) and was just wondering if I should pick up an O2 sim or if my old one can be rethreaded into the new pipe easy. I'm running stock PCM for now and stock mufflers. I like the sound its got now, just a little bit more noise would be nice. I'm sure that res is clogged to sheet as its never been touched since new. The mufflers and cat were cleaned out just before I bought it but should probably be done again/replaced but there's only so much money. Thanks in advance.
  2. #2 Re: rear O2 for U bent delete
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    i would go with a o2 sim or you can make your own using this guide OQCGP :: Ontario Quebec Club Grand Prix
    for rethreading you would have to buy a o2 bung and weld it to your new pipe so that it can thread in o2 Bung - ZZP
  1. Benefits of ant EGR delete ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 05-27-2012, 05:39 PM
  2. a/c delete
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2008, 11:09 AM
  3. delete
    By PWNED in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-04-2008, 11:45 AM
  4. delete?
    Last Post: 07-27-2008, 03:04 PM
