Thread: HID's in stock housings, question about bulb angle
Results 1 to 3 of 3
  1. #1 HID's in stock housings, question about bulb angle
    Jul 2012
    VA
    I just installed a set of Bi-Xenon HID's in my '01 and I really like them, the low beams are amazing, however I feel that the high beams are slightly lacking and I am curious if it has anything to do with the angle at which the bulbs are installed (since the bulbs change position when you click them to high-beam).
    On a standard halogen 9007 bulb the bulb mount is notched allowing the bulb to only go in to the housing in one position. With the 9007-3 HID bulbs you can mount them in any position that you want.
    Is there a "preferred" position to insert the bulbs for maximum performance? Does it make any difference at all how they are placed in the housing?
    Thanks in advance for any tips or tricks with these new lights!
  2. #2 Re: HID's in stock housings, question about bulb angle
    the filaments arent positioned correctly and they never will be because of the shape of the bulb in comparison to stock.
    also, the reflectors arent designed for that type of bulb. even though they are brighter, they will never work as effectively as the stock halogen bulbs.
  3. #3 Re: HID's in stock housings, question about bulb angle
    Jul 2012
    VA
    Thank you Bio! I will just live with what I've got then.
  1. WTB: Stock Fog Light Housings and Headlight Control Switch
    By ImColeTrickle in forum Wanted To Buy - Parts
    Last Post: 06-20-2012, 05:20 PM
  2. Fog lamp bulb replacement question
    By Frank217 in forum Visual/Body Modifications
    Last Post: 06-21-2010, 05:04 PM
  3. HID's in stock fog housings?
    By 2000GTP in forum Visual/Body Modifications
    Last Post: 10-21-2009, 01:41 PM
  4. Light bulb question?
    By toolguy in forum General Tech Discussion
    Last Post: 09-10-2009, 10:50 AM
