Thread: 3rd Brake light INOP.
Results 1 to 6 of 6
  1. #1 3rd Brake light INOP.
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    1997 Grand Prix GT 4 door.
    3rd brake light (high mount) (the one in the rear window) does not work. Bulbs good, connections good, not getting power. Is there a connection somewhere I should be looking at, downstream in the harness? The left and right brake lights work, running lights work, just no 3rd brake light.
    Any insight would be appreciated.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  2. #2 Re: 3rd Brake light INOP.
    Ontario, Canada
    Bump? Anyone have a wiring diagram I can work with maybe?
    Jay
  3. #3 Re: 3rd Brake light INOP.
    in my regal there is a harness to the 3 rd light, it plugged in under the rear deck panel on the pass side. looks like it went into the trunk.
    edit: you need to remove the whole back seat to get the rear deck off.
  4. #4 Re: 3rd Brake light INOP.
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by 98GPGT2D View Post
    Jay
    3rd Brake light INOP. Attached Images
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: 3rd Brake light INOP.
    Ontario, Canada
    Thanks Bronco.
    My GF has her drivers test on Tuesday, and I have to get the 3rd brake light working for then. I think for now, im going to run a wire from the tail light harness, up to the 3rd, to get her through the drivers test, and will find and properly fix the issue there after. Now, my question is, do you have the tail light harness wiring diagram? I'm looking for the brake light signal wire for either the left or right rear tail light. I would use a test light to find out, but I dont have a 2nd person around right now to press the brake pedal so I can probe the connection in the RR corner.
    I think its the brown wire I need to tap into? I already found out that the green and yellow are the signals, from the previous diagram you posted up. Black is ground, so it only makes sense that brown is the brake signal?
    Jay
  6. #6 Re: 3rd Brake light INOP.
    if you tap into the brake wire, and then to the 3 light, that should work. if it dont, you now know its the socket or its ground.
  1. decisions on tail light tint, third brake light and reverse bar done
    By jteske88 in forum Visual/Body Modifications
    Last Post: 06-05-2012, 05:42 AM
  2. 4th brake light
    By mosley in forum Visual/Body Modifications
    Last Post: 04-14-2011, 02:15 PM
  3. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  4. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  5. my 4th brake light and 3rd reverse light
    By HART in forum Visual/Body Modifications
    Last Post: 11-05-2009, 01:33 PM
