Thread: Fuel Pump Resistor
Results 1 to 17 of 17
  1. #1 Fuel Pump Resistor
    GT Level Member Beelzeboul's Avatar
    Racine
    so I installed fuel pump and hotwire kit today and I'm having an issue I have read about several times
    the car will fire up run fine and than sputter out after about 3 seconds
    8. Locate the Fuel Pump Resistor (on inner fenderwell behind battery on GT/GTP and behind headlight
    on Regal GS) and disconnect connector. Attach jumper connector included in the kit.
    this is the step I think im having issues with I had just unplugged the harness located directly behind the battery
    wondering if the resistor I need to disconnect is located elsewhere or in the fuse box
    so out of curiosity I plugged the harness directly behind the battery on the fenderwall back in and the car is running fine.....
    can anybody tell me what exactly the fuel pump resistor does cause it seems like car won't run without it
    is it possible my ground on the hotwire kit is bad and the fuel pump resistor connection is keeping it grounded out?
    allowing it to run
    I'm sorry officer I didnt know I couldn't do that
  2. #2 Re: Fuel Pump Resistor
    Portland Oregon
    You need to use the jumper that came with the kit. It triggers the fuel pump speed control into high
  3. #3 Re: Fuel Pump Resistor
    Racine
    yeah just says to disconnect the old one and add jumper I pretty much copy pasted the instructions in original post.
    if you could pm or post a pic of how you got your assembled it would help a great deal
  4. #4 Re: Fuel Pump Resistor
    Racine
    now why would they not put that in instructions....how exactly is that little thing assembled and whats gonna happen driving it without it disconnected?
  5. #5 Re: Fuel Pump Resistor
    Portland Oregon
    No negative effects. It was in my instructions. Did you get the Caspers kit?
  6. #6 Re: Fuel Pump Resistor
    Portland Oregon
    All you do is plug the little jumper piece into the connection on the car side of the harness and you're good
  7. #7 Re: Fuel Pump Resistor
    Racine
    my jumper connector consist of about 6 pieces
    2 platic harnesses that interlock two securing rubber gromit type things and than 2 wire connectors that would appear to go over a pin
    gonna link a pic here
    think I'm missing something here cause the resistor harness looked like it had 3 pins figured this was for hooking up a booster
    whats kinda funny to me is receipt said 3800 casper hotwire kit
    bag said ls1 fuel pump rewire kit but instructions inside listed all vehicles it could be used for and 97-03 grand prix was there
    http://intense-racing.com/Merchant2/...Code=3800_Fuel
    this is the instructions I was going off of and came printed out for me in bag
    now I completely understand assembling this might just be general or common knowledge but it seems a little more prudent to inform someone of wtf this is rather than illustrate unplugging harnesses....
  8. #8 Re: Fuel Pump Resistor
    Beez...
    Take out the fuel pump speed relay (info is on the inside of your relay center cover), bend either pin 85 or 86 so it won't interfere with anything in the box and put it back in. Poof.. you are done.
  9. #9 Re: Fuel Pump Resistor
    Racine
    yup they didn't give me the piece this was their response nice to know Im not nearly as retarded as my car would have me believe
    Hi Robert,
    Spoke with Caspers and they agreed with your approach of bending the tab on the relay to bypass the resistor. Since the current for the pump is coming through the bypass kit and the old pump circuit is only there to trigger a relay, then bending the tab is the easiest way to get the job done.
    I’ll be working with them on future kits to include the bypass connector mentioned. We had had it in older kits, but since the resistors went away after 1999 cars, it was omitted in recent batches.
    If you have any other questions, please don’t hesitate to email or call.
    Thanks!
    John Rucker
    INTENSE Racing
    614.873.6499
    INTENSE-Racing.com
    INTENSE Racing - Plain City, OH - Auto Parts Store, Automotive Customizing | Facebook
    From: weed4meplzzz@aol.com [mailto:weed4meplzzz@aol.com]
    Sent: Monday, September 24, 2012 10:56 PM
    To: JohnR@INTENSE-Racing.com
    Subject: recent purchase casper wiring kit
    so I was able to get everything installed but am having an issue with step 8
    after wiring everything up starting at the rear and working the slack to the hood and than mounting fuse holder and alternator wire the only pieces left in the kit
    were 6 components im sending a link to my photobucket
    [IMG]http://i1013.photobucket.com/albums/af258/beelzeboul/IMG_20120924_213117.jpg[/IMG]
    now I thought this was for a booster hookup but figure I must be wrong as of now the car starts and runs but it seems like I could be doing some sort of damage by driving it so was gonna wait to hear back from a member of your staff before proceeding
    So my questions are
    the fuel pump resistor is just a harness behind the battery running up from the passenger side of the front bumper. is this correct?
    am I missing a part of the assembly?
    is there anyway you could send or link me a pic of the pieces shown assembled?
  10. #10 Re: Fuel Pump Resistor
    Racine
    well I had seen that bypass.
    still a little pissed they sent me the wrong part with the kit .
    do pumps ever get stuck in low speed because of this resistor I have heard of them starting and killing a car because it has blown
    but I'm just wondering if its possible the car would start and run fine just not kick the pump into high speed for me at higher revs
    en route to parts store to grab a fuel pressure tester hopefully the resistor was my misfire component as well
  11. #11 Re: Fuel Pump Resistor
    Portland Oregon
    That pic you posted is a pic of a connector to wire in if you wanted a boost a pump. I'll snap a pic of what you should use. It's possible you are missing the required piece.
  12. #12 Re: Fuel Pump Resistor
    I've never heard of a pcm not kicking the pump in, it's based on TPS IIRC.
  13. #13 Re: Fuel Pump Resistor
    Portland Oregon
    Here's what the jumper that came with my kit looked like. You can also make one of these by clipping the resistor side of the harness and using an all weather crimp to crimp the wires together.
  14. #14 Re: Fuel Pump Resistor
    BTW..if you plan the relay pin bend as a long tern thing. Don't bend it. Cut it off. Little dremel wheel works like a champ.
    ps.. told ya so.
  15. #15 Re: Fuel Pump Resistor
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    The picture says 97-00. Will this not work for an 02 GTP?
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  16. #16 Re: Fuel Pump Resistor
    Yes it will
  17. #17 Re: Fuel Pump Resistor
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    Old thread but I too am having issues with the Casper Fuel pump re-wire.
    I'm not sure if it's the re-wire but the pump never primes.
    I have the power ran to the back of the alternator, put the ground in the back by the fuel pump with a self tapping screw.
    All the plugs are connected.
    I am using this connector since I'm using a after market pump.
    http://www.casperselectronics.com/ca...product_id=995
    Thought it could be the fuel pump resistor, but I can't even find mine so did the relay tab bend but pump still won't prime.
    I still have my ZZP re-wire hooked up and pump works with it. Thats ran to the stock wiring so that doesn't explain much.
    Don't know what else to do?
    Thanks
    Steven
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  1. where do i buy fuel pump resistor
    By grhein in forum General Tech Discussion
    Last Post: 07-12-2011, 01:12 PM
  2. Fuel pump resistor!!!
    By seanparker3 in forum General Tech Discussion
    Last Post: 06-19-2011, 03:19 PM
  3. fuel pump resistor
    By kevins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2011, 09:05 PM
  4. fuel pump resistor
    By GTPgurl in forum General Tech Discussion
    Last Post: 01-07-2011, 09:19 AM
  5. fuel pump resistor
    By gnjim in forum General Tech Discussion
    Last Post: 03-02-2009, 08:26 AM
