Thread: changed fuel level sensor, now not starting
Results 1 to 10 of 10
  1. #1 changed fuel level sensor, now not starting
    GT Level Member sasquatch094's Avatar
    cleveland
    I changed the fuel level sensor on my 2001 grand prix, now she wont start. I replaced my last grand prixs sensor and i thought i did everything the same except today i had the car running and pulled the fuel pump fuse, last time i pulled it and just tried to start the car...
    But it doesnt seem like im getting any fuel at the rails now. The pump will kick on when you cycle the key but only run for about 5 to 7 seconds then turn off. I took off the line right after i "primed" the fuel pump and i didnt even get any fresh fuel meaning the pump isnt working..
    Where did i mess up or what going on? I checked all my ignition fuses and fuel fuses in the engine compartment and they were fine.
    I replaced it wit Dorman part number 911-008. its not the supercharged 3.8.. everything plugged in fine. the car obviously ran before this, i was just fixing the stupid level for the gauge.
    any help???
    replaced fuel pump relay, no help.. no security light on either
  2. #2 Re: changed fuel level sensor, now not starting
    Check your hose connections. I don't think it's possible to hook them up ...maybe one popped off the supply etc.
  3. #3 Re: changed fuel level sensor, now not starting
    cleveland
    i checked those a few times, even took it out and replugged in everything. I checked for a crack in the line that goes from the fuel pump up but didnt see anything..
  4. #4 Re: changed fuel level sensor, now not starting
    The obvious thing would be the smell of gas and or it on the ground.
    How about the electrical. You sure that you hear the pump? If that's good..then I'd think maybe your pump took a dump when you disturbed it.
  5. #5 Re: changed fuel level sensor, now not starting
    cleveland
    i hear it, i have the backseat down and the cover off the floor, it actually priimes for around 3 to 4 seconds.. not sure what to do. im not getting any pressure what so ever. pump dead?
  6. #6 Re: changed fuel level sensor, now not starting
    I'd check pressure and power.
  7. #7 Re: changed fuel level sensor, now not starting
    cleveland
    im pretty sure theres no pressure what so ever. i hit the shradder valve with a screw driver and nothing came out with the key on.. Damn thing worked 2 seconde prior to me pulling it out. idk.
  8. #8 Re: changed fuel level sensor, now not starting
    Ok..well..what did ya do?
    Maybe bend a pin or something?
  9. #9 Re: changed fuel level sensor, now not starting
    cleveland
    hell if i know.. lol I check everything twice. The fuel gauge is working correctly and isnt moving around, but now just the pump wont pump? ****..
  10. #10 Re: changed fuel level sensor, now not starting
    And you hear it. Darn.. guess it's bad then.
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. P0440 Evap control cel? Just added new fuel level sensor and CAI
    By ST0NGE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2012, 04:31 PM
  3. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  4. P0463 Fuel Level Sensor Circuit High Voltage = ECM, PCM code
    By WonBadGTP in forum General Tech Discussion
    Last Post: 02-14-2011, 08:41 AM
