Thread: are fuel sender units compatible with other brand gauges?
Results 1 to 3 of 3
  1. #1 are fuel sender units compatible with other brand gauges?
    regret buying a prosport electrical fuel pressure gauge with a full 0-100psi sweep. i had to send back the fuel sender unit 3 times as it was faulty after 2-3 weeks each time and quite frankly im fed up with it. i only had to pay shipping for a POS sender unit made in taiwan . for now the gauge is still on but since its not connected to anything its pointed to ful pressure whenever theres a 12v source is powered on. my question is if i can get another company's fuel sender unit and connect the wires from the gauge to it and have it working right and not broken?
  2. #2 Re: are fuel sender units compatible with other brand gauges?
    would this work?
    sending unit
  3. #3 Re: are fuel sender units compatible with other brand gauges?
    Barksdale AFB, LA
    You would need to find one that matches the markings on the Prosport one exactly. The PSI range, and the Ohms range.
    2009 Subaru Impreza WRX STI
  1. Fuel pressure gauges
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-28-2008, 08:03 PM
  2. garage mod - GP compatible
    By TyroElite in forum Off Topic Discussion
    Last Post: 03-06-2008, 01:28 PM
  3. Oil Level Sender Thread
    By Speeder in forum Turbo
    Last Post: 01-08-2008, 09:25 PM
