Thread: seeing some knock retard
Results 1 to 20 of 37
  1. #1 seeing some knock retard
    GTX Level Member blakgtp's Avatar
    Sep 2011
    Vancouver
    did a couple wot runs last night and i got up to 3.8 degrees of kr. should this concern me? current mods are 3.4 pulley, sd headers, 104 plugs, dhp pcm. should i up pulleys to a 3.5 or 3.6?
    97 gtp- 3.5 pulley, sd headers, autolite 104's, dhp pcm, hai, 180 t-stat SOLD
    94 skyline- drift slut SOLD
    97 rx7 fd3s twin turbo SOLD
    99 R34 skyline
  2. #2 Re: seeing some knock retard
    GrandPrix Junkie
    Mar 2012
    NC
    A/F ratio & timing? Who did the tune?
  3. #3 Re: seeing some knock retard
    Sep 2011
    Vancouver
    i have no wideband and it's a dhp pcm. also i live in bc, so it's limited for tuners for grand prixs here
    99 R34 skyline
  4. #4 Re: seeing some knock retard
    Is the KR there all the time or come in once the car gets to higher speeds and RPMS?
    Weather changes can affect the car alot and cause many changes.
  5. #5 Re: seeing some knock retard
    Sep 2011
    Vancouver
    i noticed when i went like 3/4 throttle on the highway while changing lanes today it went to 1.2degress. and then last night at wot it was 3.8 degrees. it's only at high rpms
    99 R34 skyline
  6. #6 Re: seeing some knock retard
    Sep 2011
    Vancouver
    also this was on a 70 degree day , clear skys. so in theory it could get worse in the winter right? i plan to eventually get a meth injection kit, or an intercooler if i find a deal, but until then, i guess i should up a pulley size?
    99 R34 skyline
  7. #7 Re: seeing some knock retard
    I'd pulley up
  8. #8 Re: seeing some knock retard
    Out West
    pulley up before it cools down more.
    Whine with your Cheese?
    Stock+Self Tuned. Going for low 14's everyday.
  9. #9 Re: seeing some knock retard
    Cambridge, Ontario Canada
    Pull your Supercharger off, port it, throw it back on & see if anything changes. Pulley up is still a good choice for the winter anyway.
    2005 E55 - stock
  10. #10 Re: seeing some knock retard
    Sep 2011
    Vancouver
    Think its worth it to get a 3.5 or just get a 3.6?
    99 R34 skyline
  11. #11 Re: seeing some knock retard
    If you can port it yourself, the larger outlet will in a nutshell, lower psi #'s a tad, lower outlet temps, which in turn lowers KR from the build up heat it had prior. It's free minus the blower gasket if you already have a dremel or die grinder...takes a couple hours or so...just make sure you check out all the how-to's if you do it...it's pretty straight forward and easy.
    Also, DHP's like to run kinda on the rich side...you have upgraded mounts or have the dog bones flipped or running a 180* T-Stat? Do those too if you haven't...super cheap.
    If you still have knock on the 3.4" after all of that...get an MPS system if you don't have one and swap the 3.6" on for the winter. It should be fine there.
  12. #12 Re: seeing some knock retard
    Banned
    Jun 2012
    Sacramento CA
    If you port a supercharger and your boost goes down, something went very wrong.
    OP I would run a 3.5, in my experience .1 bigger on the pulley was good for eliminating 3-4 degrees of KR.
    What would really help is a full tune, but since you don't have access to that playing with other stuff is pretty much your only option.
    Depending on how much boost you're seeing on the 3.4 it'll probably get worse come cold weather. For example if you're already seeing 11-12psi... Theres a goldie locks zone that the m90 likes to be in and weather brings it to both extremes with changes in season.
  13. #13 Re: seeing some knock retard
    Quote Originally Posted by fry626 View Post
    Really?
    Care to explain?
    Less restriction, same pulley size, same amount of air...since the Eaton M90 is a roots style blower and it creates boost by restriction...what happens when you remove that restriction? Oh...psi levels dip a little. Same reason you lose boost levels when you go from factory manifolds to headers. Flow.
    But I'll be here all day.
  14. #14 Re: seeing some knock retard
    Banned
    Jun 2012
    Sacramento CA
    Porting a supercharger correctly makes the blower more volumetrically efficient, not the engine. More air coming through the blower means more boost since the engine VE hasn't changed.
    Headers make the engine more volumetrically efficient, that's why boost goes down.
  15. #15 Re: seeing some knock retard
    lol, hi flake.
    Ohio
    Soooooooo tvs>all
    Amirite?
  17. #17 Re: seeing some knock retard
    Sep 2011
    Vancouver
    I would like to port the blower, but im going to college 5 days a week and working, car is my dd. so i ill install the 18 tstat
    if theres still knock ill pulley down
    99 R34 skyline
  18. #18 Re: seeing some knock retard
    Quote Originally Posted by blakgtp View Post
    Up, right?
  19. #19 Re: seeing some knock retard
    180* should help compared to the factory 195 unit...when I was scanning the car the temp of the motor actually sat anywhere from 10-20* above rated temp...when the silver N/A car I had was stock...it would get pretty toasty, think like 220-230* sitting. Even people that don't recommend the 160* don't realize the car really never gets under 170* once it is warmed up...cruising on the highway in the winter that is...think it was like single digit temps. My headter worked just fine too. Sitting in traffic on a hot day with the A/C it would still get close to 190*. 160's aren't as bad as they are cracked up to be but the 180* is the most practical choice.
  20. #20 Re: seeing some knock retard
    Nah, down = more race.
  1. New Knock Retard
    By Bluemagic in forum General Tech Discussion
    Last Post: 09-19-2012, 09:22 AM
  2. knock retard
    By RideWithPride in forum General Grand Prix Discussion
    Last Post: 08-19-2012, 11:41 AM
  3. 5* of knock retard at WOT please help
    By asite57 in forum General Tech Discussion
    Last Post: 06-15-2012, 08:45 PM
  4. Knock retard on a NA
    By Ophidia in forum General Tech Discussion
    Last Post: 02-22-2012, 11:10 PM
  5. Knock Retard
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 01:05 AM
