Thread: ABS not working
Results 1 to 4 of 4
  1. #1 ABS not working
    SE Level Member john cola's Avatar
    Sep 2012
    willmar minnesota
    Redid the front brakes on my 2000 gtp, and afterward the anti lock brakes system does not work and the abs light remains on. any ideas? no big deal not having the abs, but winter is coming here in minnesota and they sure are handy when the roads are snowy. any ideas?
  2. #2 Re: ABS not working
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Check your abs sensor wiring on the wheel hub. Common failure.
    GPONA #1 Cyber Bully
  3. #3 Re: ABS not working
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    i second the wheel bearing
    __________________________________________________ __________________________________________________ ______________________stage 3 zzp heads,sd headers,ss m90 kit,3in cat back,AEM wide band,cai,evap egr rear 02 delete.
  4. #4 Re: ABS not working
    Sep 2012
    willmar minnesota
    when I first bought the car, the abs worked and the light was not on. then I had the front wheel bearing replaced and that's when the abs trouble started. i bet the clowns at midas screwed it up. I'll have them check on it. thanks.
  1. DIC not working
    By 1996pontiac in forum Audio, Security & Visual Electronics
    Last Post: 05-16-2012, 06:56 AM
  2. 03 GTP D.I.C Not Working!???
    By WaterBoy in forum General Tech Discussion
    Last Post: 01-28-2012, 10:46 PM
  3. DIC still not working...
    By zql8tr in forum Audio, Security & Visual Electronics
    Last Post: 12-12-2010, 09:49 AM
  4. HUD not working
    By tdm571 in forum Audio, Security & Visual Electronics
    Last Post: 11-28-2010, 09:05 PM
  5. site working and then not working etc.
    By Rocket468 in forum Site/Club News
    Last Post: 03-24-2010, 11:53 PM
