Thread: o2 sensor or catalytic coverter
Results 1 to 20 of 34
  1. #1 o2 sensor or catalytic coverter
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    hey guys quick question. my service engine soon light went on and i went to the local auto parts store and got it read. It comes up saying either the o2 sensors are bad or my catalytic converter. Is there any way of knowing which o2 sensor is bad or if those aren't even bad and i need a new catalytic converter or is it just kind of luck of the draw?
    Thanks
  2. #2 Re: o2 sensor or catalytic coverter
    Whats the code number?
    The code number will tell you what sensor it is coming from.
  3. #3 Re: o2 sensor or catalytic coverter
    Houston
    Not without the code.
  4. #4 Re: o2 sensor or catalytic coverter
    Jun 2012
    Illinois
    P0420
  5. #5 Re: o2 sensor or catalytic coverter
    Houston
    Catalytic Converter
  6. #6 Re: o2 sensor or catalytic coverter
    Jun 2012
    Illinois
    okay how do you know exactly and where would you suggest to get one
  7. #7 Re: o2 sensor or catalytic coverter
    Houston
    Have you noticed any loss in power or a rotten egg smell?
  8. #8 Re: o2 sensor or catalytic coverter
    Jun 2012
    Illinois
    lol no smell and not really in power i've been babying it because it has a 3.4 pulley without headers waiting to get my stock pulley.. when i do start it it seems to struggle a little
  9. #9 Re: o2 sensor or catalytic coverter
    Houston
    I would clear it and see if it's an anomaly. If it comes back, go with an OEM cat or you will see that code a lot.
  10. #10 Re: o2 sensor or catalytic coverter
    Jun 2012
    Illinois
    and how are zzp's catalytic converters?
  11. #11 Re: o2 sensor or catalytic coverter
    Houston
    Not OEM. They are high flow and you will need that code tuned out if you dont want to see it.
  12. #12 Re: o2 sensor or catalytic coverter
    Jun 2012
    Illinois
    alright thanks and also how would you suggest clearing it
  13. #13 Re: o2 sensor or catalytic coverter
    Houston
    With a basic code reader (the same thing the parts store read the code with), or aeroforce scan gauge.
  14. #14 Re: o2 sensor or catalytic coverter
    Jun 2012
    Illinois
    oh sorry i read that wrong... some reason i thought u ment like cleaning it and would autozone be able to do that
  15. #15 Re: o2 sensor or catalytic coverter
    Houston
    You can try, they won't usually clear codes though. They'd rather you buy the part the code is pointing to. You can buy a cheap code reader, though. They're good to have
    Amazon.com: Actron CP9125 PocketScan Code Reader: Automotive
  16. #16 Re: o2 sensor or catalytic coverter
    Jun 2012
    Illinois
    alright thanks for all your help
  17. #17 Re: o2 sensor or catalytic coverter
    May 2012
    Burlington, Wisconsin
    What would the rotten egg smell be from? I put an aftermarket cat on my GTP and I have the rotten egg smell and a check engine light is on. Haven't scanned yet though.
    1998 GTP Sedan: Gen III, Speedy Daddy Headers, SLP Catback, Magnaflow High Flow Cat, Open Cone Intake, Autolite 104s, Debadged, more to come!
  18. #18 Re: o2 sensor or catalytic coverter
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    Often, an aftermarket cat will not "clean" the exhaust enough for the computer and through the code. If you do not notice any egg smell or have reduced power an easy fix is a piece of black electrical tape over the ses light.
    Favorite Quote: You can't fix stupid!!
    http://www.youtube.com/watch?v=0gxKStPXyn8
  19. #19 Re: o2 sensor or catalytic coverter
    Starting in 2000 GM got tougher on the standards in the pcm. Before 2000 you could do almost anything and be ok. What year is the car?
  20. #20 Re: o2 sensor or catalytic coverter
    Jun 2012
    Illinois
    My car is an 01 and it has an intense racing pcm ( bought the car like that)
  1. catalytic converter CEL, how to replace catalytic converter
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2012, 11:53 PM
  2. sensor after catalytic converter
    By jerrysalley in forum General Tech Discussion
    Last Post: 01-05-2011, 09:36 PM
  3. clogged catalyist coverter?
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2010, 11:22 PM
  4. catalytic converter
    By c002529 in forum General Tech Discussion
    Last Post: 10-07-2010, 11:45 AM
